owenpga
trying to center spry menu bar
Apr 5, 2012 4:58 AM
Tags: #spry_menubar
Hello,
I just tried to use the info below to center my spry menu bar after widening the web page.
It doesn't seem to make any changes when i enter change the code.
www.owendawsonpga.com
If anyone has suggestions on what i need to do differently please feel free to comment.
Thank you.
Owen
Editing the style sheet
The style rule that controls the position of a horizontal Spry Menu Bar is the first one in the style sheet. It looks like this:
ul.MenuBarHorizontal { margin: 0; padding: 0; list-style-type: none; font-size: 100%; cursor: default; width: auto; }
Notice that the margin property is set to 0. That zeroes the margin on all four sides. To centre the menu, change the margin property like this:
margin: 0 auto;
On its own, that won't centre the menu, because the width property is set to auto. You need to change auto to the actual width of your menu bar. By default, a Spry Menu Bar contains four top-level items, and sets their width (in the ul.MenuBarHorizontal li style rule) to 8em.
So, to centre a default Spry Menu Bar, you need to change the width property in the ul.MenuBarHorizontal style rule to 32em. With both changes, the style rule looks like this:
ul.MenuBarHorizontal { margin: 0 auto; padding: 0; list-style-type: none; font-size: 100%; cursor: default; width: 32em; /* Change to the width of your own menu bar */ }
    Apr 5, 2012 5:13 AM   in reply to owenpga
    Hi Owen,
    sorry, had been too fast, 'cause David's hints are working like a charm, have to look further and deeper.
    Hans-Günter
    Apr 5, 2012 8:13 AM   in reply to owenpga
    The rule on your posted link does not appear to contain the revised rule...
    have you not uploaded it?
    FROM YOUR SERVER CSS
    padding: 0;
    font-size: 100%;
    cursor: default;
    width: auto;
    text-align: left;
    background-position: center;
    margin-top: 0;
    margin-right: auto;
    margin-bottom: 0;
    margin-left: auto;
    Replace with this rule
    /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
        padding: 0;
        font-size: 100%;
        cursor: default;
        width: 49em;
        text-align: left;
        margin: 0 auto;}
    HTH
    Apr 5, 2012 8:02 AM   in reply to owenpga
    Hi Owen,
    as a first step I used David's hint about the width and put it into your source code like this:
    margin: 0 auto;
    padding: 0;
    font-size: 100%;
    cursor: default;
    /* width: auto;*/
    width: 32em;
    text-align: left;
    and I got this:
    what means you/I haveonly to "Adjusting the menu item widths", what is described here: http://foundationphp.com/tutorials/sprymenu/customize3.php#widths.
    Good luck!
    Hans-Günter.
    P.S.
    The first time I used your source code in my DW I got this message:
    Please have a look to it there.
    Apr 5, 2012 9:14 AM   in reply to owenpga
    Hi Owen,
    at the end I got this:
    and therefore I wrote in your SpryMenuBarHorizontal.css:
    margin: 0 auto;
    padding: 0;
    font-size: 100%;
    cursor: default;
    width: 860px;
    text-align: left;
    and
    ul.MenuBarHorizontal ul
    margin: 0;
    padding: 0;
    font-size: 100%;
    z-index: 1020;
    cursor: default;
    width: 10.7em;
    position: absolute;
    left: -1000em;
    Hans-Günter
    Apr 9, 2012 11:19 AM   in reply to owenpga
    Hi Owen -
    We can improve your centering even further.than with just the CSS code I provided
    You have used the HTML code in your page to alter the display size of the images on your page.
    No need to change the image, but In the HTML code, on your pages, change the size of your banner to match the actual size of your image.
    Change this -
    <h1 align="center">
    <img src="photos/pgabanner_w_phonenumber.png" alt="Owen Dawson PGA Instruction" width="773" height="220" /></h1>
    To this -
    <h1 align="center">
    <img src="photos/pgabanner_w_phonenumber.png" alt="Owen Dawson PGA Instruction" width="812" height="232" /></h1>
    Unrelated to your centering problem, you again disregarded the actual image size on your "Book a Lesson" JPG image. I am posting a drastically reduced sized image which I converted to a GIF  image with a transparent background (to hide the white canvas) and a slightly different shadow. See if you like it better when you insert it at its actual size of 138x117 rather than using HTML code to constrain the original 500x427 image. This will also speed up the download time of your page.
    If you can't save the image from this Forum, please let me know, and I'll email it to you.
    Welcom home pal.
    Apr 9, 2012 11:50 AM   in reply to owenpga
    Hi Owen,
    in addition to Ken's idea about the image size now (see my message below), seriously, you could feel satisfied for the moment (I can imagine that you prefer "hio" for that matter) as well with your solution as our proposals to your ul.MenuBarHorizontal ...
    Now you could take your time experimenting with the different dimensions and sizes (px, em, % aso.) AFTER you have performed your most important technical tasks at your web presence.
    Naturally, no offence and good luck!
    Hans-Günter
    Message modified by hans-g.
    Apr 9, 2012 11:47 AM   in reply to owenpga
    Hhm,
    the note before mine dissapeared, or?
    Hans-Günter
    Apr 9, 2012 11:55 AM   in reply to hans-g.
    Yes Hans... it sure did disappear -
    I'll add it again here.
    Hi Owen -
    Change this -
    <h1 align="center">
    To this -
    <h1 align="center">
    Let;s see if this one stays
    Apr 9, 2012 1:39 PM   in reply to Ken Binney
    OT:
    Hi Ken, only to satisfy my curiosity: Chris Cox = Ken Binney?
    Hans-Günter
    Apr 9, 2012 2:03 PM   in reply to owenpga
    Actually, centering a Spry menu is easy, once you fix the flaws in the default CSS:
    http://www.projectseven.com/testing/spry/center-menu/
    Al Sparber - PVII
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Apr 9, 2012 2:03 PM   in reply to hans-g.
    Nein, neither one of us wants to be mistaken for the other *grin*
    Apr 9, 2012 2:39 PM   in reply to Ken Binney
    OT: I know there is therefore nothing more important than this!
    Hi Ken,
    only to show you that your sentences came to me from a Mr. Chris Cox:
    Header 1Header 2
    BUT, maybe there is a mistake at Adobe's Forum Software, and it could be important to look after it, perhaps.
    Hans-Günter
    Apr 18, 2012 10:45 AM   in reply to owenpga
    Try this transparent background GIF with shadow
    Apr 20, 2012 6:19 AM   in reply to owenpga
    owenpga wrote:
    but right now i have it working so i'm not going to mess with things.
    I feel your frustration... I ran into exactly the same phenomenon on www.peattiecapital.com/
    and I'm still afraid to touch it *LOL*  Sometimes it would happen, sometimes not, It seemed to
    depend on which sequence of links I tested.
    Apr 20, 2012 2:53 PM   in reply to owenpga
    PROBLEM:  Spry widget code contains various browser hacks which DW's Design View doesn't know how to translate -- it gets confused.
    WORK AROUND:  When editing Spry Menus (or any widget for that matter), turn off CSS rendering in DW.
    View > Style Rendering > un-tick Display Styles.
    You'll see an unstyled HTML page which is usually easier to edit.  Also, this won't effect Styles in Live View or Preview.
    Hope this helps,
    Nancy O.
    May 3, 2012 11:17 AM   in reply to owenpga
    Not my strong suit Owen.
    Please make a new post, with an appropriate Subject line, and include a link to a problem page online.
