whiteSpaceCollapse not working on textFlow created from HTML
Jun 3, 2010 12:31 PM
Is there a trick to getting whiteSpaceCollapse to work with imported HTML? Here's my current code, where value is HTML text (e.g. "<p>Blah</p>.."):
textFlow = TextConverter.importToFlow( value, TextConverter.TEXT_FIELD_HTML_FORMAT);
textFlow.whiteSpaceCollapse = WhiteSpaceCollapse.COLLAPSE;
I've also set whiteSpaceCollapse on the RichEditableText to "collapse" but I'm still noticing vertical space differences if my external HTML has linebreaks between <p></p> nodes. Many thanks in advance for any suggestions.
-Robert
    Jun 4, 2010 10:51 AM   in reply to ROBERT REINHARDT
    WhiteSpaceCollapse is applied as part of the import.  After that changing it or modifying it has no effect.
    Richard
    Dec 15, 2011 3:27 PM   in reply to rdermer
    And so ? How do we set the TextConverter to avoid collapsing white spaces on import now ?
    I ve tried many ways but still no way to avoid a WEIRD behavior.
    If I set spaces and I want to collapse them, then I can do it with a simple search/replace, there are plenty
    of regex out there to do this.
    I don't need the framework to behave strangely right ? So why did the flex engineers spend time
    on putting together stuff that is totally weird ?
    Plus the TextConverter has a lot of tlf_internal methods, just to avoid us to overload its functionnalities...
    Dec 15, 2011 9:23 PM   in reply to aliman
    Hi aliman,
    Did you set format string to TextConvertr.PLAIN_TEXT_FORMAT ? That will preserve your spaces I think.
    var textFlow:TextFlow = TextConverter.importToFlow(markup, TextConverter.PLAIN_TEXT_FORMAT);
    And for tlf_internal, i just find one tlf_internal function in TextConverter. Others are public.
    static tlf_internal function setFormatsToDefault():void
    Apr 9, 2012 11:16 AM   in reply to ROBERT REINHARDT
    this is the way to solve this bug and no need for changing any xml settings , simple and it works
    exporting the textflow:
    var richTextXML:xml = new XML("<"+"richTextXML"+"/>");
    richTextXML.appendChild(getCdataXMl());
    private function getCdataXMl():xml{
      var textFlowStr:String = TextConverter.export(textFlow,TextConverter.TEXT_FIELD_HTML_FORMAT
    , ConversionType.STRING_TYPE).toString();
    var textFlowXMl:xml = new XMl("<![CDATA["+textFlowStr+"]]>");
    return textFlowXMl;
    importing TextFlow from XMl :
    var htmlTextInStr:String = richTextXMl.text();
    var importtedTextFlow:TextFlow = TextConverter.importToFlow(htmlTextInStr,TextConverter.TEXT_FIELD_HTM L_FORMAT);
    textArea.textFlow = importtedTextFlow;
