"An unexpected error occur processing your request." when launching Muse.
Apr 9, 2012 12:19 PM
Tags: #install #unexpected_error
Reinstalled AIR and Muse 7 on Windows and try to log in on Adobe ID. ID works, I am logged in here.
Issue since Friday. Several questions in this forum but no answers.
Message was edited by: Corey@Adobe Edited title to accurately describe the issue/error
Replies 1 2 3 Previous Next
    Apr 9, 2012 11:56 AM   in reply to Pixelhopper
    Are you running a firewall? Muse needs to be able to make an http connection to Adobe's servers. Firewalls usually allow this, but it's possible your firewall is set up to block certain http connections. Please try turning off any firewall running on the machine and see if that resolves the error.
    Apr 9, 2012 12:20 PM   in reply to Corey@Adobe
    Corey,
    That still didn't work :/. I've tried to allow Muse through and then turned off the firewall but it's a no go. Is there anything else I can do?
    -Amy
    Apr 9, 2012 1:43 PM   in reply to Apayne25
    Amy,
    Are you running on a corporate network, or a home network? The following are the exact addresses you need to be able to reach through your firewall:
    https://ims-na1.adobelogin.com  : 192.150.3.146
    https://adobeid-na1.services.adobe.com  : 192.150.3.150
    https://na1r.services.adobe.com  : 192.150.3.51
    If you're running on a corporate network it is likely that there are network rules causing this block.
    Apr 9, 2012 2:34 PM   in reply to Pixelhopper
    Yes, starting with Beta 7 we require authentication to verify use eligibility.
    Apr 9, 2012 2:40 PM   in reply to Corey@Adobe
    Corey,
    I am on a home network. Would my firewall still block those addresses?
    -Amy
    Apr 10, 2012 12:40 PM   in reply to Pixelhopper
    Corey,
    None of that is working. What else will fix the problem????? Please help!!
    -Amy
    Apr 10, 2012 1:18 PM   in reply to Apayne25
    Your firewall or some other utility may be blocking Muse from connecting. Please make sure you are not running any other utilities (e.g., norton, etc) that could be preventing Muse from connecting to Adobe servers.
    If you are certain no other utilities are running, please try searching for and deleting your MBLStore/* and OOBE/opm.db files on your machine. Doing this may resolve the error.
    Calculating status...
    Apr 10, 2012 2:45 PM   in reply to Corey@Adobe
    Our IT people insist that there is nothing blocking my requests to the links you provided in an earlier response.  We turned off anything that could have blocked access, and I still can't get Muse to start or even ping those IP addresses.  In addition, I don't have the files on my machine that you said I should remove.
    Apr 10, 2012 3:22 PM   in reply to Pixelhopper
    Corey,
    I do not seem to have either of those files and I have turned my firewall off, still with no luck. However I do have a text document in my Documents labeled Muse Log. Does that have anything to do with the problem? In an earlier thread someone asked about it and I never found out the answer.
    -Amy
    Apr 10, 2012 3:47 PM   in reply to Apayne25
    I don’t have a Muse.log (that I can find with Windows search), and I still get the unexpected error.
    Apr 12, 2012 11:16 AM   in reply to Pixelhopper
    If you are seeing the first screen 'Unknown Error', could you please check to see if the file /User/<user>/Application Support/Adobe/OOBE/opm.db (Mac) or  \Users\<username>\AppData\Local\Adobe\OOBE\opm.db (Win) exists. If it does not, could you please email me the log file /Users/<user>/Logs/PDApp.log (Mac) or %temp%/PDApp.log (Win) to boag@adobe.com.
    Apr 12, 2012 11:24 AM   in reply to James Boag
    I am not getting an “Unknown Error,” but I am getting “An unexpected Error...”
    I have the opm.db file on my Windows 7 machine.  Interestingly, it isn’t found by Windows search.
    Apr 12, 2012 11:34 AM   in reply to AlanKarp
    Thanks, Alan. Would you be able to send me the log from %temp%/PDApp.log to boag@adobe.com?
    Apr 12, 2012 2:29 PM   in reply to James Boag
    I sent you my %temp%/PDApp.log
    -Amy
    May 28, 2012 1:41 PM   in reply to Pixelhopper
    I'm using a mac on wifi and I get the unexpected error. When I plug in my ethernet cable, it signs in ok. I cant really use my ethernet cable due setup. It would be strange to always have to plug in a cable to use muse instead of wifi all day. Any new resolution on this issue?
    Mike
    May 28, 2012 2:35 PM   in reply to STSMikeyMike
    Are you using the Mac's Airport for wifi or some other mechanism (i.e. a broadband wifi card)?
    May 28, 2012 2:55 PM   in reply to Zak Williamson (Adobe)
    im using the built in wifi airport on macbook pro unibody. no aircard or external device. just wifi into my router connected to my modem.
    May 28, 2012 4:37 PM   in reply to Zak Williamson (Adobe)
    Zak, is there any solution? Sounds like many people are receiving that message. I know its new and some bugs may appear but it use to work, but not perfectly and it would take a few tries to finally get through. Right now, it will not let me through and simply stop trying every hour. This is a paid service. Thanks!
    Mike
    May 30, 2012 9:00 PM   in reply to STSMikeyMike
    I've been assuming you're the same Michael that James has been having a lengthy e-mail dialog with and we're now waiting on a server-side adjustment to your account. If that isn't you, please let me know and I'll see this thread gets attention. Thanks.
    May 31, 2012 7:45 PM   in reply to Zak Williamson (Adobe)
    I am having the exact same problem. I do not have a firewall. Any help would be appreciated.
    Jun 1, 2012 5:53 AM   in reply to Zak Williamson (Adobe)
    Hi Zak, did you come up with a solution? I can't get past the same screen. Thanks for your help.
    Jun 3, 2012 2:01 PM   in reply to Pixelhopper
    I'm having the same issue.  I can't connect on my home or my corporate network.  I'm not running any firewall.  I am running Windows 7.  Each time I try, I'm prompted by a dialog box about the certificate being unknown or untrusted.  Could this be part of the problem?  Please advise.
    Jun 4, 2012 9:48 AM   in reply to Pixelhopper
    well, any news on this topic?
    would like to test the actual release trial but i cant sign in cause of this unexpected error thing=(
    Jun 4, 2012 9:58 AM   in reply to tetrochuan
    I've been emailing back and forth with the Adobe Team and they resolved my issue. The mentioned that there was some crossup in the subcription under my account. THey had to clear the server state on their backend. Sorry I cant be a little more detailed but that's what I was told and it's fixed. Seems like they also released an update for muse. I was able to contact them via email at muse-support@adobe.com.
    Jun 9, 2012 3:43 AM   in reply to Pixelhopper
    Hi I just started to get this error at the worst time. I just migrated to a new mac and get the above error when I try and log in. All my other adobe software is fine. I uninstalled, re-downloaded and ran all updates but nothing changed. I do not even have a firewall activated so very much doubt this can be the issue.
    Anyone able to help?
    Jun 11, 2012 9:00 AM   in reply to ZICI
    Count me in as another who is getting this error and can no longer connect to get up and running.  I've been using Muse for a few months and this just came up out of the blue around June 10.  I'm a Windows 7, 64bit user.  Firewall shouldn't be an issue.
    Jun 11, 2012 12:20 PM   in reply to pacificachris
    Hi ZICI and pacificachris,
    Would you please email me the log file /Users/<user>/Logs/PDApp.log (Mac) or %temp%/PDApp.log (Win) to muse-support@adobe.com (with the subject FAO James)? That will help us to diagnose the cause of this issue for you, and provide a resolution.
    James
    Jun 11, 2012 8:16 PM   in reply to James Boag
    Hi James, I can't find the file you are referring to. It has been 3 days without my main piece of software and it's costing me money. Cheers Rose
    Jun 11, 2012 9:50 PM   in reply to ZICI
    Mac OSX 10.7.x hides some folders.
    Go to "Go to Folder..." in the "Go" menu in the Finder and type "/Users/<yourusername>/Logs" and click "Go". In the folder that appears, find the PDApp.log file and please send it to muse-support@adobe.com with a link to this thread and ATTN James. Thanks.
    Jun 11, 2012 10:30 PM   in reply to Zak Williamson (Adobe)
    As you can see from the attached screen grabs this folder can not be found. Rose
    Jun 12, 2012 11:01 AM   in reply to ZICI
    Hi Rose,
    If you open Finder and then select Go > Go To Folder from the top menu, then type in ~/Library/Logs that should take you to the correct folder (even though it may be hidden, in 10.7/Lion and later versions of Mac OS). There, you should find the PDApp.log file.
    Best,
    James
    Jun 17, 2012 7:32 PM   in reply to STSMikeyMike
    Still no fix here? Going off ST Mikey Mike's post there's a mixup of account subscriptions, and it seems to be affecting quite a few people.
    Just downloaded an update, same error. Win 7. I have the .db file in OOBE.
    We have to individually email muse-support@adobe.com to have it fixed?
    Jun 17, 2012 8:15 PM   in reply to RedOctopus
    There are multiple different causes of login failures. In order of frequency:
    1) opm.db file becomes corrupted and must be deleted. We're working to isolate the cause of this.
    The opm.db file can be found in the OOBE folder in:
    on Mac: <yourusername>/Library/Application Support/Adobe
    on Windows XP: <youruser>\Local Settings\Application Data\Adobe
    on Windows 7: <youruser>\AppData\Local\Adobe
    Deleting this file will often address the error.
    2) Inability to get to the internet. This is most commonly due to unusually strict firewall settings or anti-malware software. Muse must be able to reach:
    https://na1mbls.licenses.adobe.com
    You can go to these links in your browser to verify they're accessible from your machine. If they load a webpage from Adobe, then the connection is working as expected.
    3) Muse incompatibility with some USB broadband connections. If your connection to the internet it through a USB broadband card, you many need to connect by other means to start your trial/subscription. We're working to address this incompatibility.
    4) Account issues that require server-side fixes. To my knowledge STMikeyMike's situation is the only one to-date that's required a server-side fix.
    Jun 17, 2012 8:26 PM   in reply to Zak Williamson (Adobe)
    Thanks Zak, deleting opm.db has fixed it.
    Jun 20, 2012 7:15 AM   in reply to Zak Williamson (Adobe)
    The First Option worked.
    Jun 22, 2012 5:34 PM   in reply to Zak Williamson (Adobe)
    i've tried to get to these sites, as suggested:
    i can get to the first one, but i'm getting "there's a problem with this website's security certificate" on the other three.  is there any way to overcome this error?  i'm running windows 7 and IE 8.
1 2 3 Previous Next
Actions
Bookmarked By (1)
