Vertical spacing of text frames
Apr 9, 2012 1:37 PM
I am creating an eBook and have defined a couple paragraph styles (Chapter, Title, Subtitle, and Paragraph). Is there a best practice for controlling the vertical spacing of text frames? I want to be sure the spacing below my text frames is the same everywhere. I don't want the spacing between "Chapter 4" and its subtitle to be different than the spacing between "Chapter 1" and its subtitle.
    Apr 9, 2012 1:51 PM   in reply to Anthonymcp
    Spacing between frames is pretty much meaningless. If you’re laying out text for epub the entire document should really be on flowing story.
    How are your HTML/CSS skills?
    Bob
    Apr 9, 2012 2:13 PM   in reply to Anthonymcp
    Let’s back up…you are talking about epub, right?
    Bob
    Apr 9, 2012 2:24 PM   in reply to Anthonymcp
    Sorry, that’s why I wanted you to clarify.
    No, a PDF is not an epub. As far as making sure things are the same, that’s what master pages and guides are for.
    Bob
    Apr 10, 2012 3:53 AM   in reply to Anthonymcp
    Guides are for the references only , they will not show up in the PDF after export , you can create the Guides on the master page which help you in layout the pages content properly in the documnet.
    in your document , Go to master pages , craete GUides as you want , come back to the document pages and align the text frames based on the guides, check the PDF.
    Apr 10, 2012 12:41 PM   in reply to Anthonymcp
    IMO, you should use one text frame for the whole document with Space after defined for the Chap Title and such. (It's worthwhile at the start of a project to set Next Style > Author for Chap Title and Next Style > Body for Author, but at this late in the project, it doesn't speed much up)
    Apr 10, 2012 1:16 PM   in reply to Anthonymcp
    Good - avoid Character Styles beyond a few words, perhaps a sentence length for a call out or quote. Character styles are too often mis-used for entire blocks of type, you've got the grasp
