CQ5
Perry H.
Unable to create Listener in Repository
Apr 9, 2012 2:20 PM
Tags: #cq5
I am doing a base install of CG 5.4 onto a Windows 7 box.  The install goes fine and I shutdown/startup CQ5.  Upon CQ5 server startup, I see the following stacktrace:
09.04.2012 15:58:45 *ERROR* RepositoryStartupServlet: RepositoryStartupServlet initializing failed: org.apache.jackrabbit.j2ee.ServletExceptionWithCause: Error while creating repository (RepositoryStartupServlet.java, line 250)
        at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.initRepository(Re positoryStartupServlet.java:415)
        at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.startup(Repositor yStartupServlet.java:242)
        at com.day.crx.j2ee.CRXRepositoryStartupServlet.startup(CRXRepositorySta rtupServlet.java:147)
        at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.init(RepositorySt artupServlet.java:215)
        at javax.servlet.GenericServlet.init(GenericServlet.java:211)
        at com.day.crx.j2ee.CRXRepositoryStartupServlet.init(CRXRepositoryStartu pServlet.java:126)
        at com.day.j2ee.servletengine.ServletRuntimeEnvironment.doStart(ServletR untimeEnvironment.java:113)
        at com.day.j2ee.servletengine.ServletRuntimeEnvironment.start(ServletRun timeEnvironment.java:93)
        at com.day.j2ee.servletengine.WebApplication.loadStartupServlets(WebAppl ication.java:702)
        at com.day.j2ee.servletengine.WebApplication.start(WebApplication.java:6 31)
        at com.day.j2ee.servletengine.ServletContainer.start(ServletContainer.ja va:318)
        at com.day.j2ee.servletengine.ServletEngine.start(ServletEngine.java:285 )
        at com.day.j2ee.server.Server.start(Server.java:227)
        at com.day.j2ee.server.Server.main(Server.java:607)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at com.day.launcher.Bootstrap.run(Bootstrap.java:118)
        at com.day.crx.quickstart.Quickstart.run(Quickstart.java:680)
        at com.day.crx.quickstart.Main.<init>(Main.java:675)
        at com.day.crx.quickstart.Main.main(Main.java:730)
Caused by: javax.jcr.RepositoryException: Unable to register data store in cluster.
        at com.day.crx.core.data.ClusterDataStore.initClustered(ClusterDataStore .java:163)
        at com.day.crx.core.CRXRepositoryImpl.createClusterNode(CRXRepositoryImp l.java:832)
        at org.apache.jackrabbit.core.RepositoryImpl.<init>(RepositoryImpl.java: 319)
        at com.day.crx.core.CRXRepositoryImpl.<init>(CRXRepositoryImpl.java:225)
        at com.day.crx.core.CRXRepositoryImpl.<init>(CRXRepositoryImpl.java:267)
        at com.day.crx.core.CRXRepositoryImpl.create(CRXRepositoryImpl.java:185)
        at com.day.crx.j2ee.CRXRepositoryStartupServlet.createRepository(CRXRepo sitoryStartupServlet.java:172)
        at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.initRepository(Re positoryStartupServlet.java:413)
        ... 21 more
Caused by: java.io.IOException: Could not create a listener on any of the following ports: [8088, 8089, 8090, 8091, 8092, 8093], and could not connect to another cluster node
        at com.day.crx.core.cluster.ClusterController.start(ClusterController.ja va:679)
        at com.day.crx.core.cluster.ClusterController.register(ClusterController .java:833)
        at com.day.crx.core.data.ClusterDataStore$Skeleton.register(ClusterDataS tore.java:611)
        at com.day.crx.core.data.ClusterDataStore.initClustered(ClusterDataStore .java:160)
        ... 28 more
I shutdown my Windows box, brought it back up and did a netstat.  None of those ports (8088, 8089, 8090, 8091, 8092, 8093) were in use.  I start up CQ5 and I still receive the the error so I don't believe it is port contention.
Thoughts on what I am doing wrong?
Perry
