Paiz
Can you find a string inside of apdf using cfpdf in Coldfusion?
Apr 9, 2012 3:06 PM
Tags: #pdf #coldfusion #cfpdf
Is it possilbe to determine if a String, for example "Not Possible",  exists in a PDF using CFPDF or another function inside of Coldfusion?  If so, any suggestions on how to do this would be appreciated.
    Apr 10, 2012 1:44 AM   in reply to Paiz
    Yes, it is possible. In the following example, the 2 files and the PDF ('myDoc.pdf') are in the same directory.
    textFromPDF.cfm
    <!--- Convert from PDF to text and search text --->
    <cfset currentDir = getDirectoryFromPath(expandpath('*.*'))>
    <cfset ddxfile = "#currentDir#myDDX.ddx">
    <cfset inputStruct=StructNew()>
    <cfset inputStruct.Doc1= "#currentDir#myDoc.pdf">
    <cfset outputStruct=StructNew()><!--- Coldfusion automatically saves the text as XML file --->
    <cfset outputStruct.Out1="#currentDir#my_PDF_doc_as_text.xml">
    <cfpdf action="processddx" ddxfile="#ddxfile#" inputfiles="#inputStruct#" outputfiles="#outputStruct#" name="myDDXVar">
    <cfif myDDXVar.out1 is "successful"><!--- read the text --->
        <cffile action="read" file="#currentDir#my_PDF_doc_as_text.xml" variable="my_PDF_doc_as_text">
    </cfif>
    Position of search text "Not Possible": <cfoutput>#findNoCase("Not Possible",my_PDF_doc_as_text)#</cfoutput>
    myDDX.ddx
    <?xml version="1.0" encoding="UTF-8"?>
    <DDX xmlns="http://ns.adobe.com/DDX/1.0/"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xsi:schemaLocation="http://ns.adobe.com/DDX/1.0/ coldfusion_ddx.xsd">
       <DocumentText result="Out1">
          <PDF source="Doc1"/>
       </DocumentText>
    </DDX>
    Apr 10, 2012 1:54 PM   in reply to Paiz
    I suspect you made the same mistake I did in the beginning. Note that there is a space before the word coldfusion in:
    Apr 10, 2012 2:38 PM   in reply to Paiz
    Hmm, challenging construction! What about first writing the PDF to disk? I know it's inefficient, but let us first get a working example.
    <cffile action="write" file="#currentDir#myNewDoc.pdf" output="#pdfBinaryVariable#" >
    <cfset inputStruct.Doc1= "#currentDir#myNewDoc.pdf">
        <!---<cfdump var="#my_PDF_doc_as_text#">--->
    </cfif>
    Apr 10, 2012 2:49 PM   in reply to Paiz
    Can you open the newly created PDF? Is its content what you expected?
    Apr 10, 2012 2:57 PM   in reply to Paiz
    Could you please show us your code.
    Apr 10, 2012 11:44 PM   in reply to Paiz
    Paiz wrote:
    By the way,  CF9 has an extracttext action on cfpdf!
    <cfpdf action="read" source="pdfFile.pdf" name="mypdf">
    <cfpdf
        action="extracttext"
        source= "mypdf"
        pages = "*"
        type = "xml"
        destination = "#currentDir#testxml.xml" >
    Ahhh, there's the kind of efficiency we want! I went with DDX from memory, as I had used it a lot in a project. I honestly didn't think of 'extractText'! Thanks for bringing it in and lightening the load.
    However, at least, as I see it, the main problem remains how to go from the byte array from the database to the text file. What about something like this:
    <cffile action="write" file="#currentDir#myNewDoc.pdf" output="#query.pdf#" >
    <cfpdf action="extracttext" source="#currentDir#myNewDoc.pdf" name="txtFromPdf">
    <p>Position of search text "Not Possible": <cfoutput>#findNoCase("Not Possible",txtFromPdf)#</cfoutput></p>
    Apr 11, 2012 12:52 PM   in reply to Paiz
    That must feel like a bit of a downer, after your discovery of the extractText action!
