Metabaronen
Small details disappears when I using eraser tool
Apr 9, 2012 3:04 PM
Tags: #illustrator #problem #cs5 #tool
I've got a problem with the eraser tool. It removes small details that shouldn't be touched.
I guess that there is a setting for  this somewhere but I can't find it :-/
    Apr 9, 2012 3:15 PM   in reply to Metabaronen
    Work with selections. Only select the objects, the eraser should erase.
    Apr 9, 2012 3:45 PM   in reply to Metabaronen
    Maybe you should post a picture. I don't get what you're trying to achieve there.
    Apr 9, 2012 4:18 PM   in reply to Metabaronen
    If you switch to outline view - are those lines really gone?
    Apr 9, 2012 4:38 PM   in reply to Metabaronen
    There is no eraser setting  you can adjust that will prevent this.
    The only settings are the calligraphy-like options that operate with a graphic tablet. You might fix them all to a smaller size and deactivate all pressure sensitivity. Maybe a pressure setting too sensitive in conjunction with smoothing of eraser lines and an area getting too small to be conserved led to this effect.
    Another option would be not to use the eraser at all.
    Instead create an opacity mask for the blob-brush lines and draw directly in it using a calligraphy brush (or a blob brush).
    You could then revert and edit at will.
    Only when all is right you'll flatten transparency and things will be erased permanently.
    Jul 5, 2012 3:48 AM   in reply to Metabaronen
    This has to be a bug, and it's driving me insane. It was there in CS3 and I just discovered it's still there in CS6. It makes the eraser tool completely useless in many situations.
    Jul 5, 2012 6:15 AM   in reply to babianen
    It's not a bug; it's just a poorly designed feature. Done right, the Eraser tool should have at long last given Illustrator at least a rudimentary ability to trim artwork containing open unfilled paths—a bare bones basic thing it has always inexplicably lacked. But as implemented, the Eraser fails at even that. The Eraser unprecictably alters the remaining portions of what it "erases." For that, since its belated appearance, I have considered it useless for 99% of what I might ever use it for.
    Thus, despite its now five different tools for cutting paths (Scissor, Knife, Path Eraser, Eraser, Shape Builder), it still to this day lacks any proper straightforward ability to simply cut/crop its own artwork. Typical AI feature glut.
    JET
