Is CS6 Photoshop a 64 bit or 32 bit Application?
Apr 8, 2012 5:04 PM
The further I get into enjoying this new version the more confussed I get. I'm using Windows 7, 64 bit with 16 gig of RAM. CS6 has installed itself as a 32 bit program. It uses some of my old and very useful 32 bit plugins but seems to be able to use memory like a 64 bit application. Can someone explain this to me please? My real concern is that a few of my 64 bit Plugins won't install a 32 bit version in CS6. Some of them won't even recognise CS6 as a destination for plugins. I'll address this with the Plugin maker but I'd really like to know if CS6 is going to be a 32 bit only version.
Doug
    Apr 8, 2012 5:55 PM   in reply to Ryadia™
    On Windows, it is a 32 and 64 bit application -- both get installed by default.
    On MacOS, it is 64 bit only.
  • Noel Carboni
    Dec 23, 2006
    Apr 8, 2012 6:50 PM   in reply to Ryadia™
    Where are you looking, specifically, for the 64 bit software?
    Photoshop CS6 is not going to behave any differently regarding access to 32 bit plug-ins.  A 32 bit app can only call functions in a 32 bit DLL (a plug-in is a special kind of DLL).  A 64 bit app can only call functions in a 64 bit DLL.  Thus a plug-in has to be specifically made for whatever bitnesses of Photoshop the author wants it to run with.  Old plug-ins, built in the time before Photoshop CS4, were necessarily 32 bit because there was no 64 bit Photoshop before Photoshop CS4.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 8, 2012 7:11 PM   in reply to Ryadia™
    Watch the dialogs carefully.
    You are looking for it in "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)" right?
    -Noel
    Apr 8, 2012 9:09 PM   in reply to Ryadia™
    If you just press OK and Next, the installer installs both 32 and 64 bit.
    You have to install to a 32 bit OS, or specifically disable the 64 bit install to only end up with a 32 bit app.
  • Noel Carboni
    Dec 23, 2006
    Apr 9, 2012 5:33 AM   in reply to Ryadia™
    What Chris is saying, Doug, is that it's supposed to work the way you expected.  That it didn't says you accidentally unchecked it or that there's an installer bug.
    For what it's worth, I've installed the Photoshop CS6 beta twice on two different Windows systems (Windows 8 x64 and Windows 7 x64) and in both cases both 32 and 64 bit applications were installed without any special choices by me.
    -Noel
    Apr 9, 2012 6:25 PM   in reply to Ryadia™
    Hi Doug.
    Are there any outstanding questions on this issue that we need to answer for this thread?
    In case there is any question as to what the answer was, for Mac Photoshop CS6 is 64 bit only. For PC both 32 and 64 bit are offered.
    Not all plugins that work on 32 bit work on 64 bit and you must be sure to install them in the right place and not point to old CS5 folders.
    Pattie
    Apr 9, 2012 9:21 PM   in reply to Ryadia™
    Hi Margie,
    Hopefully things get sorted out with the install on that machine and the default install works as expected. What about manual intevertion to check on the 64-bit version makes this unusable for you? It sounded like Doug's post #6 had a viable and reasonable workaround for the Ps CS6 Beta.
    regards,
    steve
