Workaround for Reader 10.1.2 print crash issue
Jan 16, 2012 6:28 AM
Dear users,
Based on the feedback provided to us in relation to the recent Print crash issues on Adobe Reader 10.1.2, we are hereby providing the following two workarounds for the problem faced. Please follow the steps below to get rid of this issue:
WORKAROUND 1:
Go to Start menu to Select Devices and Printers to access all Network Printers installed on your machine. Right Click to access Printer Properties. Open the Sharing Tab and give your printer a Share Name. If you wish not to share your printer then you may choose to give it a Share Name and then select “Do not Share” Checkbox. Please make sure that all Network printers have been assigned a Share name otherwise problem will persist. Please find below the screenshot for your reference.
WORKAROUND 2:
The second work around is to turn off the Protected Mode of the Reader and the problem will be resolved right away. However, it is not advised to keep the application in non-protected mode due to security reasons and it is advisable to turn this setting ON once you are done with your printing task. You can access this setting by going to Edit-->Preferences-->General pane and can find “Enable protected mode at start-up” at the bottom of the window. Please re-start the Adobe Reader after you have made changes to this setting.
Atul Agarwal
    Jan 17, 2012 3:25 AM   in reply to Atul Agarwal
    Dear Atul Agarwal,
    I tried workaround 1, but these settings are already present.
    Because of the secure environment I'm working in, I think it's not save to turn off the Protection Mode (We receive hundreds of emails with attachments everyday).
    Are there any other suggestions and will adobe come up with a permanent solution on short notice?
    Thank you in advance,
    Jan 17, 2012 5:40 AM   in reply to Atul Agarwal
    Dear Atul Agarwal
    the same issue here. Workaround2 doesnt work and Workaround1 is not possible because we have more then 120 printers!
    Where can i download Version 10.1.1?
    Its very important for us to print PDF documents. Maybe we have to install another tool.
    Stefan
    Jan 17, 2012 7:12 AM   in reply to Atul Agarwal
    Dear Atul,
    we use Windows Server 2008 R2 Terminalserver with Citrix XenApp. On this Server we cant print since the upgrade to 10.1.2.
    When i disable the protected mode is the same issue.
    The older Version 10.1.1 works fine. So i want install the version 10.1.1 again because i dont have time for testing someting.
    Where can i download that version?
    If i can not install 10.1.1 i install another pdf viewer. Its too important to wait. Sorry.
    Stefan
    Jan 17, 2012 7:21 AM   in reply to p1800s
    You can find the 10.1.1 installer here - ftp://ftp.adobe.com/pub/adobe/reader/win/10.x/10.1.1/en_US/
    Jan 18, 2012 2:29 AM   in reply to Atul Agarwal
    Great,
    Workarround 2 works for me. I search a few hours and reinstall it... and and and..
    Thanks.
    Jan 18, 2012 2:33 AM   in reply to Atul Agarwal
    No, because we have several Terminal-Servers and about 25 printers. So the second Workarround is mutch faster to implement.
    Guy
    Jan 18, 2012 9:13 AM   in reply to Atul Agarwal
    Is there a quick way to push out Workaround 2 to thousands of machines? All of our printers are pushed via group policy and therefore, your Workaround 1 is not an option. I am half tempted to push out FoxIt Reader to fix these issues for good. However, this issues will probably be fixed with Adobe releases yet another update to Reader next week. Maybe 10.1.3 will fix the issues, but 10.1.4 will probably break them again.
    Jan 18, 2012 10:41 AM   in reply to Atul Agarwal
    Workaround 1 is not a workaround for me - it doesn't work!!  Workaround 2 works and I will therefore be keeping the unprotected mode as "normal".  Are Adobe going to fix this in the near future.  I want to enable protection again asap but because of the inconvenience of this workaround ..........  I get many PDFs daily and therefore this is my only option.
    Jan 23, 2012 1:59 AM   in reply to Atul Agarwal
    Hi.
    Workaround 1also is not a woraround for me. In Citrix published Apps Printers are mapped on connection. They are not shared by default.
    Feb 3, 2012 8:24 AM   in reply to Atul Agarwal
    We've had to leave protected mode off since 10 came out due to a bug with embedding PDFs in Excel.  Still waiting after all these years...
    Feb 3, 2012 5:33 PM   in reply to Atul Agarwal
    Neither workaround 1 nor 2 work for me. I have a very small network, but my printer stands alone on the lan.
    I'm running Windows 7 SP 1. My printer is an hp oj pro 8500 hardwired via lan. When I installed Reader 10.1, all printing stopped. It doesn't crash, but finds the printer, starts to process the file, then a "Save As" window pops up and it wants to save the file as a *.pm. If I cancel, nothing happens and nothing prints. If I Save, it takes a long time (> 1min)  to process the file (simple text, 1 page), then the status box vanishes and nothing prints. I can't find the .pm file anywhere and there is nothing in the printer's queue.
    I installed 10.2.1. Same thing. Tried the patch for 10.2.1 printer crash (even though I'm not really crashing. Just a whole lot of nothing) and same problem.
    Reader 10.1.1 on my mac has no problems finding the printer. I'm leery of upgrading it to version 10.2.1 But we only have the one mac, and I'm stuck with the hp pc.
    Feb 9, 2012 6:51 PM   in reply to Atul Agarwal
    I work from home on a PC with a Lexmark printer.  I have never had any problems printing PDF files.  My tech guy was here today doing some cleanup and he downloaded the new version of adobe.  I now cannot print any PDF files.  I select print and nothing happens.  My printer is working fine for all other printing.  I tried both of the workarounds you mentioned and still nothing.
    Apr 9, 2012 8:11 PM   in reply to galspdf
    Is there a way I can do option #2 for all users on the Terminal Server?  I'm having to do this for each user individually and I've got over 150 users.
    Apr 11, 2012 6:22 AM   in reply to Atul Agarwal
    Adobe Reader 10.1.3 is generating an error at address 0x00720065 ("Memory could not be written.")  when printing, similar to the problems the workaround were intended to solve in 10.1.2.  Do those workarounds still work for 10.1.3, or should a different approach be taken?
    Apr 11, 2012 8:51 AM   in reply to Atul Agarwal
    I'm hesitant to move forward with the update until I see a response from SirLysander that everything is working.  Hopefully he'll follow up.
    Apr 11, 2012 9:57 AM   in reply to Vastidious7
    The site this occurred at has a number of users (30+) with 10.1.3 that aren't reporting a problem... and the one user that is.  Squeaky Wheel and all that; Atul; I emailed you earlier, I had already uninstalled/reinstalled yesterday, before I found this message thread.
    Apr 25, 2012 9:43 AM   in reply to Atul Agarwal
    Hello, after a lot of searching I have found little information and am still unsure as to whether this issue has been resolved with 10.1.3 or not.
    I need to put this on our XenApp 6.5 Farm, and am unwilling to disable protected mode. Will Adobe Reader work or should I be looking at something like PDF Xchange..?!
    Apr 25, 2012 9:45 AM   in reply to iHateAdobeSoftware
    The printing issue has been addressed in 10.1.3. http://helpx.adobe.com/acrobat/kb/pdf-wont-print-reader-10.html
    Jun 4, 2012 7:18 PM   in reply to AbhigyanModi
    I updated to 10.1.3 and still had the problem. I tried solution #1 and solution #2 and still had it. I cimpletekyunistalled Adobe Reader and instakled 10.1.3 from scratch, I tried both solutions, and still cannot print a PDF.
    How do I reinstall a 9.x version for the time being?
    Jun 6, 2012 12:45 PM   in reply to aa789
    I went back to Adobe Reader 9.5.1 and the problem still exist.  With 9.5.1 I was able to click print, see the printer, after choose the printer, click OK, the whole Adobe Reader disappeared.  With 10.3.1 click print, Adobe Reader disappeared.  So version 9.5.1 let me go a few steps further.  But it still has the same problem of not printing.  Anyone has any idea what Adobe is doing about this?
    Jun 8, 2012 2:06 AM   in reply to Catho1215
    Still using 10.1.1 without any problems.
    I do wonder when they are seriously solving this problem.
    Jun 11, 2012 9:00 AM   in reply to AbhigyanModi
    Unforunately, at the office we are still experiencing the same issue. We are using network printers and all printers (even the PDF writers, etc.) have share names (though are not shared).
    The Acrobat software is fully up-to-date (10.1.3).
    Aug 18, 2012 10:00 AM   in reply to SgtSideburns
    Looks like you're right.  Just updated to v10.1.4 and the problem as described above has occurred.  Workaround: use Nitro PDF instead; that (and other apps such as Word) prints with no problem.
    Aug 31, 2012 2:48 AM   in reply to tjbi
    For us the problem has persisted for a while, but updating the Lexmark Universal printer driver to v. 2.0.4. solved the problem.
