pooolve
Script for making random thumbnails from single image
Apr 7, 2012 2:19 PM
Tags: #photoshop #script #random #scripting #rotation #cropping #automation #thumbnail
Hi all,
I need something like a hundred different thumbnails from each image in a series of images, that is, hundred random sections of the same image, saved in a folder as jpg,  and i was hoping that i could find a script for this.
What the script has to do is:
  1. select the size of the crop (this would also be the dimensions of the thumbnail saved)
  2. rotate crop selection in a random orientation and place the crop randomly on the canvas
  3. save the image as a jpg in a folder
  4. return to original image,
  5. repeat process x times before quitting script.
I dont think this should be to difficult to make a script for, but unfortunately i don´t know how to code.
Is there anybody that could help me with this?
This would save me a lot of time!
    Apr 9, 2012 4:31 AM   in reply to pooolve
    Maybe because you have not considered the difficulty of calculating the offset of the rotated content so as not to exceed the existing image’s edge – or maybe your math-skills are just better than mine.
    In any case it should be possible to achieve the intended result.
    What do you need it for, if I may ask?
    Edit: Not 100% sure about the randomization, but the resulting files look fairly random …
    Apr 9, 2012 10:53 PM   in reply to pooolve
    You can give this a try:
    // create copies with pseudo random clipped and rotated parts of image;
    // thanks to xbytor;
    // 2012, use at your own risk;
    #target photoshop
    if (app.documents.length > 0) {
    var originalRulerUnits = app.preferences.rulerUnits;
    app.preferences.rulerUnits = Units.POINTS;
    // set name for folder to save jpgs to;
    var folderName = "rotatedJpgs";
    // set number of jpgs;
    var theNumber = 100;
    // width and height;
    var theWidth = 500;
    var theHeight = 500;
    // calculate some values;
    var theDiagonal = Math.sqrt ((theWidth * theWidth) + (theHeight * theHeight));
    var diagAngle = angleFromRadians(Math.acos((theWidth) / (theDiagonal)));
    // get file name and path;
    var myDocument = app.activeDocument;
    var docName = myDocument.name;
    try {
              var basename = docName.match(/(.*)\.[^\.]+$/)[1];
              var docPath = myDocument.path;
    catch (e) {
              basename = docName;
              var docPath = "~/Desktop";
    // create folder if it does not exist yet;
    if (Folder(docPath + "/" + folderName).exists == true) {
              var docPath = docPath + "/" + folderName;
    else {
              var theFolder = Folder(docPath + "/" + folderName).create();
    // document dimensions;
    var docWidth = myDocument.width;
    var docHeight = myDocument.height;
    // jpg options;
    var jpegOptions = new JPEGSaveOptions();
    jpegOptions.quality = 10;
    jpegOptions.embedColorProfile = true;
    jpegOptions.matte = MatteType.NONE;
    // duplicate image;
    var theCopy = myDocument.duplicate (theCopy, true);
    var origResolution = theCopy.resolution;
    theCopy.resizeImage(undefined, undefined, 72, ResampleMethod.NONE);
    var docHalfWidth = theCopy.width / 2;
    var docHalfHeight = theCopy.height / 2;
    var theLayer = smartify2010(theCopy.layers[0]);
    theCopy.resizeCanvas (theWidth, theHeight, AnchorPosition.MIDDLECENTER);
    var theHistoryState = theCopy.activeHistoryState;
    // do the variations;
    for (var m = 0; m < theNumber; m++) {
    var theAngle = Math.random() * 360;
    theLayer.rotate (theAngle, AnchorPosition.MIDDLECENTER);
    //theCopy.resizeCanvas (theWidth, theHeight, AnchorPosition.MIDDLECENTER);
    // get tolerance offset;
    var theHor1 = Math.abs(Math.cos(radiansOf(theAngle + diagAngle)) * theDiagonal / 2);
    var theVer1 = Math.abs(Math.sin(radiansOf(theAngle + diagAngle)) * theDiagonal/ 2);
    var theHor2 = Math.abs(Math.cos(radiansOf(theAngle - diagAngle)) * theDiagonal / 2);
    var theVer2 = Math.abs(Math.sin(radiansOf(theAngle - diagAngle)) * theDiagonal / -2);
    // calculate max offset for unrotated overall rectangle;
    var thisHalfWidth = docHalfWidth - Math.max(theHor1, theHor2);
    var thisHalfHeight = docHalfHeight - Math.max(theVer1, theVer2);
    // calculate random offset for unrotated overall rectangle;
    var randomX = thisHalfWidth * (Math.random() - 0.5) * 2;
    var randomY = thisHalfHeight * (Math.random() - 0.5) * 2;
    var aDiag = Math.sqrt (randomX * randomX + randomY * randomY);
    var anAngle = angleFromRadians(Math.asin((randomY) / (aDiag))) + theAngle;
    anAngle = anAngle + Math.floor(Math.random() * 2) * 180;
    // calculate  offset for rotated overall rectangle;
    var offsetX = Math.cos(radiansOf(anAngle)) * aDiag;
    var offsetY = Math.sin(radiansOf(anAngle)) * aDiag;
    //alert (theAngle+"\n\n"+offsetX +"\n"+ offsetY+"\n\n"+ thisHalfWidth+"\n"+thisHalfHeight);
    theLayer.translate(offsetX, offsetY);
    theCopy.resizeImage(undefined, undefined, origResolution, ResampleMethod.NONE);
    theCopy.saveAs((new File(docPath+"/"+basename+"_"+bufferNumberWithZeros(m+1, 3)+".jpg")),jpegOptions,true);
    theCopy.activeHistoryState = theHistoryState;
    // clean up;
    theCopy.close(SaveOptions.DONOTSAVECHANGES);
    app.preferences.rulerUnits = originalRulerUnits;
    ////// radians //////
    function radiansOf (theAngle) {
              return theAngle * Math.PI / 180
    function angleFromRadians (theRad) {
              return theRad / Math.PI * 180
    ////// buffer number with zeros //////
    function bufferNumberWithZeros (number, places) {
              var theNumberString = String(number);
              for (var o = 0; o < (places - String(number).length); o++) {
                        theNumberString = String("0" + theNumberString)
              return theNumberString
    ////// function to smartify if not //////
    function smartify2010 (theLayer) {
    // make layers smart objects if they are not already;
              app.activeDocument.activeLayer = theLayer;
    // process pixel-layers and groups;
          if (theLayer.kind == "LayerKind.GRADIENTFILL" || theLayer.kind == "LayerKind.LAYER3D" || theLayer.kind == "LayerKind.NORMAL" ||
          theLayer.kind == "LayerKind.PATTERNFILL" || theLayer.kind == "LayerKind.SOLIDFILL" ||
          theLayer.kind == "LayerKind.TEXT" || theLayer.kind == "LayerKind.VIDEO" || theLayer.typename == "LayerSet") {
                        var id557 = charIDToTypeID( "slct" );
                        var desc108 = new ActionDescriptor();
                        var id558 = charIDToTypeID( "null" );
                        var ref77 = new ActionReference();
                        var id559 = charIDToTypeID( "Mn  " );
                        var id560 = charIDToTypeID( "MnIt" );
                        var id561 = stringIDToTypeID( "newPlacedLayer" );
                        ref77.putEnumerated( id559, id560, id561 );
                        desc108.putReference( id558, ref77 );
                        executeAction( id557, desc108, DialogModes.NO )
                        return app.activeDocument.activeLayer
              if (theLayer.kind == LayerKind.SMARTOBJECT || theLayer.kind == "LayerKind.VIDEO") {return theLayer};
    ////// get an angle, 3:00 being 0˚, 6:00 90˚, etc. //////
    function getAngle (pointOne, pointTwo) {
    // calculate the triangle sides;
              var width = pointTwo[0] - pointOne[0];
              var height = pointTwo[1] - pointOne[1];
              var sideC = Math.sqrt(Math.pow(width, 2) + Math.pow(height, 2));
    // calculate the angles;
              if (width+width > width) {theAngle = Math.asin(height / sideC) * 360 / 2 / Math.PI}
              else {theAngle = 180 - (Math.asin(height / sideC) * 360 / 2 / Math.PI)};
              if (theAngle < 0) {theAngle = (360 + theAngle)};
              return theAngle
    Apr 10, 2012 4:06 AM   in reply to pooolve
    By the way, you need to adapt
    var theWidth = 500;
    according to your needs.
    The names should be clear enough, width and height are in pixels.
