hi
I have indesign cs3 files utilising the interactive buttons and are then exported to pdf. I have upgraded to cs5.5 and the 'close pdf' button I created in cs3 no longer works. On double checking the button panel, the option for 'next page, previous page, etc' is still there but the 'close' option is gone. This means the close button on every page of the 24 page documents no longer works. These files are outputed to pdf. Why has this been removed. This is the second button option removed in the cs5.5 upgarde. We lost the email to a friend option 'attached to email' in acrobat and now functions are missing in inDesign!
Beside our clients still wanting this function, there is no way you can close a full page pdf (without menu bar) unless clicking the Esc button on your keybaord. If you are on a tablet it is then really awkard
Granted the Close PDF option has been removed in InDesign CS5.5 (I don't know why). But you can still create a button in Acrobat which has that action. Select the button tool and create a button. Choose as an action Execute a Menu Item. Click Add, and choose File > Close.
Not as convenient as doing it in InDesign, but Acrobat has many other menu commands which are not accessible in InDesign.
yes thanks I can do it that way but there are 24 pages per document and we do a couple of documents a week so its out of the question to manually code the button on each page of each document. Why in heavens would they take it out. I am getting really fed up with adobe. Its costing us money!
Like I said, I don't know why they removed it. One guess: With InDesign CS4, CS5 and CS5.5, InDesign added the ability to create SWF files. If you notice, there are some actions now which are PDF-only; some actions which are SWF-only; and some actions which are for both. They may have found that the File > Close action wasn't being used by many people (frankly, you're the first person I've run into who uses it), and dropped a couple lesser used commands to add those from SWF output.
Just a guess.
I did that with Acrobat 10. Are you using Acrobat 8 or 9? This is a quote from Acrobat 8 help:
To duplicate the form field on a limited range of pages, click the From button, and type the start and ending pages on which you want the form field to appear.
