CQ5
Need a help in adding customized properties to component.
Apr 9, 2012 1:45 AM
Need a help in adding customized properties to component and make use of the properties in the template in which the component was used. This is like to configure some key & values in component level which is configured by admin user the at the time of component creation.
    Apr 9, 2012 12:42 PM   in reply to palani046
    Palani,
    What exactly do you want to do?
    Can you explain the situation?
    The properties you can add to a component by CRX DE (Lite or no), by right-clicking in the component, selectiong "New" > "Propertie", or just right-click a empty line bellow the components on Properties dialog and clicking on "Add new".
    Most of the properties of the components define only it's type, parents or structure and system node values. Don't know exactly how to create "keys and values" properties to use on your application, maybe is the same way.
  • Justin Edelson
    Nov 24, 2010
    Apr 10, 2012 4:35 AM   in reply to palani046
    Have you looked at http://dev.day.com/docs/en/cq/current/howto/components_develop.html?
    You also might want to sign up for CQ Developer training. You can see a schedule here: http://bit.ly/Hpqgcs
