DW050 Installation errors and where do I file my install logs?
Apr 8, 2012 8:11 PM
Tags: #issues #installation #ashinst
I've just installed Photoshop CS6 on an i7 PC wiht 16 gig of RAM and plenty of hard drive space. I've got 25 errors and 2 warning in the install logs. Can someone please tell me where or to whom I should send this file?
Doug
    Apr 8, 2012 8:09 PM   in reply to Ryadia™
    Thanks, we'll take a look at them. What OS and video card are you using on your pc?
    What other Adobe products are installed?
    Pattie
    Apr 8, 2012 11:36 PM   in reply to Ryadia™
    OK. I see you have Windows7 with service pack 1 and a compatible video board. That is good. Will you be trying to re-install the Photoshop CS6 beta for him or waiting for his return?
    Pattie
    Apr 8, 2012 11:40 PM   in reply to Ryadia™
    To be safe, you should go to the site listed below and download the file. Extract it from the zipped folder and install it. You will get 32 and 64 bit installed unless you specify otherwise. Unless there are special circumstances on your system, it should install and run. Be sure not to point your plugins to the CS5 plugins, which is a common mistake people make. Let us know how it  goes!
    Pattie
    http://labs.adobe.com/technologies/photoshopcs6/
    Apr 9, 2012 10:07 AM   in reply to Pattie F
    Hi Doug,
    Please provide me with the  ################installer logs to look into the issue, You can find it at:
    Program files (x86) /Common Files/Adobe/ Installer
    Look for logs by name Adobe Photoshop CS6 13.0 mm-dd-yyyy.log.gz
    Please send them to me at: asnigam@adobe.com
    Ashutosh
    Apr 10, 2012 4:59 AM   in reply to Ashutosh.Nigam
    Try following the below mentioned steps:
    1) Reboot your system
    2) Re-download the installer, Unzip the installer using winzip or winrar
    3) Run the the set-up.exe by using clicking on the right mouse button and choosing Run As Administrator.
    Please let me know if it helps, Otherwise I will setup a connect session to resolve the issue.
    Ashutosh
    Apr 13, 2012 10:18 AM   in reply to Ryadia™
    Hi Doug,
    Please check your personal messages and send me the required details.
    Ashutosh
