Not sure if this is the same "Feature" or a different one.
InDesign CS5 - WIndows 7 x64
Some of our users can use the 'Text Wrapping" feature other users cannot. Users have local admin rights.
The error will not allow the user to set the Font Styles or use the Text Wrapping feature.
Reloading Creative Suite didn't help ![]()
No, not a peep. It appears that Adobe has closed the book on this bug, even though it is still annoying us on a regular basis.
To be honest, on my end, I think I'm only seeing it in old files. It may be something that can't be removed from old files but the bug no longer occurs in freshly-generated-from-scratch documents. It's hard for me to judge this myself because I'm working off of templates and will be for a couple years. Working on fresh documents is rare for me, but I did start a new project the a few weeks back in which I started from scratch and created new style sheets and everything, and I have yet to see the issue in that one. I'm even using split and span columns.
I just tested it this morning (in response to Peter's question about being patched to the latest version, not initially realising that he was responding to T.S.Hulbert's problem). I can still reproduce the bug in the exact same way as in my post on 31 August:
Can you reproduce this?
@ Peter Not sure if that's really useful with my current template. It's actually a flowed story and everything template-oriented is in the text of the story. Even the wrapped objects that misbehave are anchored objects that are part of the flowed story. However, I'm near the end of the first year of layout on this 3-year project, and I was already planning on redoing the templates for the second year—there are some things I want to change in the templated flow. I'm hoping that I can shed the error when I do that.
@Rhiannon I'm still on OS 10.5.8. I've been happy not to move to Snow Leopard because all my coworkers who have it experience persistant network problems.
Hmm. I'm on Lion. But to be honest I'm really not sure how much difference that could possibly make – I can't see how it could have fixed itself when you haven't changed version at all. Is there anything you've changed recently? Plugins? (I have a couple, but a colleague has none at all and can reproduce the bug as described above.)
I don't know if anyone is still following this thread, but I have been having exactly the same problem in CS5.5. This is the first time I have used the Span Columns feature in a document and also the first time I have seen this problem occur. I have a 300-page book with double columns and several graphics per page, each with text wrap. Any time I make a change to a page, the text wrap randomly gets "forgotten" by many of the graphics beneath the change, even in the non-spanned columns. This is extremely tedious to have to go through a hundred or more pages and "refresh" each graphic by making a slight change to the text wrap dimension of the graphic and then changing it back, which seems to reset the text wrap to its proper settings.
It appears that they did not fix this bug in CS5.5 after all; and I had never seen this issue before upgrading to CS5.5 The next book I design I will not use the Span Columns feature; I'll see if it continues to occur.
Anyone?
