I have a scrolling content using the pan-only feature. The MSO at the end of the series of scrollable MSOs became smaller. I had this working fine the first time but now,I have been getting the same frustrating issue even after I recreated the whole process and re-loaded a new article. I am in a tight deadline and I have to work on 200 more content with a features like this.How can I resolve this issue? What causes this behavior? And how can I prevent this from happening again?
regards,
Mikke
I haven't tested this issue much, so I can't provide as detailed an answer as you'd like. My understand is that the shrinking problem occurs if you cut or copy and object on the pasteboard and then paste it onto the layout. I don't think it's a problem if you move objects on and off the pasteboard.I know this bug was reported and I believe it's fixed for v20.
@BobB – I wonder if it might help expanding the bleed area or better: the slug area. If that's the case one could define a large slug area to be on the safe side and working from there. Of course there are limitations in width and height of that area, but one could overcome that limit by scripting (that's my knowledge out of experience with CS4, for CS5.5 I still have to test that).
The slug area definition (in the UI) for left is not limited by a small amount (limit for the other sides are 152.4 mm or 432px), so we could easily define a slug area for left to e.g. 4000px.
Uwe
Hi Bob,
I'm getting the shrinking MSO effect on my scrolling content. Could you clarify best working practice with current v19?
I have a long 'document' within a scrolling frame, previously I have made a large pasteboard and done my MSO creation & placement there, then done the linking to external MSO's once the content has been cut and pasted into the scrolling frame. When I added further MSO slideshows (three in total) 2 of them shrunk that were outside the frame boarder.
Is the right way to create my MSO in another (dummy) document and then copy from that document and paste into the scrolling frame on my (working) document, the scrolling content is way bigger than the frame so can't see how to do this in the same document.
Thanks for any help here.
Hugo
Thanks for your response Bob,
I'm still finding the MSO shrinking tho, even if I create a new doc and work only within the page space and not the pasteboard.
My scrollable frame is 960 x 772 but my content area is 6470 x 772 with 3 MSO's spaced throughout, creating a new page doesn't help as it's impossible to edit without some of the content being on the pasteboard.
What's strange is that the shrinking only happens when I position the MSO's within the scrollable frame but outside the frame edge (i.e. off the page). If I position the content and use the 'Use Document Position' with the MSO within the frame edge (on the page) it works fine.
I hope that makes sense, if you have any thoughts I'm listening, I can't seem to figure this out even though folk seem to have achieved this using the methods explained.
Hugo
