Setup: Two colour book, images in PMS 125 and black, text in black. 125 does not feature anywhere else in the book outside of images.
Should I be setting screen angles via the File -> Print -> Output dialogue, or export the PDF as per usual and let the prepress sort it out at their end? I did ask on behalf of the client about what they wanted and didn't get a proper answer, so I am perhaps a little worried that they aren't grasping the nature of the problem.
Other option is changing the PSD to PS EPS and swinging the angle there, but that gets a little time expensive ...
Would love to hear if anyone else has crossed this bridge.
Nathan
Thanks all.
Feels like the problem is in communication - it's a publishing house in HK and English isn't the primary language.
My preference was for them to set angles, as it's their machine, but failing that, a simple 'You set it yourself' would have been the go. I did ask what they would like me to set at, and the answer I got second hand was '30 degrees', which I did deduce as black @ 40 degress, PMS 125 30 degrees off.
Steve, we've seen their work and it's pretty good, so pretty sure it's just a communication breakdown.
If I use 'Print' in ID, is that the best way to set angles? Does that hangle image compression and line art as good as the 'Export' function? And does it crop image data to frames, to keep the size managable?
Thanks guys, appreciate the wisdom/warnings.
Nathan
My postscript printers ignore any screens or transfer curves saved with an EPS file—the angles I set in the print dialog are always used when I print separations. Angles don't get save in print presets, so I don't there's a way to set screen angles and frequencies on your end that would make it through production downstream.
