I've been working with files created by another user. I have exported to idml file then saved as indd. It still is crashing. I've installed the lastest updates and according the crash report http://pastebin.com/5SVUfNsU it's saying something about plugins... unfortunately I have now idea about plugins. I've tried to reset preferences and can't find any folders mentioned from another report (common crash issues)
It has also crashed when tryin to export either idml or indd files to pdf.
I'm not an "avid" used of indesign. I'm just learning so I really need some guidance.
Your crash report looks to me like it is related to optical kerning, but it also mentions preflight. Try turning off Live Preflight and see if that helps.
Are you able to open InDesign without a crash, and to open or create other files, or does ID immediately crash now on opening or crash on any file you try to work with?
Renamed recovery folder. Opened indd file, it stayed open until I changed something in the document then it crashed. http://pastebin.com/U3m26s9Y here is the data. Opened the idml file and did the same change no crash. Saved idml file to indd file..tried to scroll up to view and document crashed not program. http://pastebin.com/taq7kmCq
Sorry it took so long for a response as everything seemed to be working (for a while) then crash and the same thing again.
I removed the "Optical Kerning.apin" plug in to the desktop and opened. It said this documents requires it but I opened anyway. It's working now (so far) as I was able to open and move things around.
Should I leave on desktop for now?
I would say "NO".....
This is a essential plugin , removing this may cause the issue in other document and layout.
Open up the document which has the issue , copy the file in the new document ...check the "kerning" setting in the document and other text settings like paragraph style , character style etc. ,,,,,basically recover the file and its content.
Move this plugin back to its original place.
Have you actually removed the optical kerning itself from the file? It's not the plugin, per se, it's something to do with the text using optical kerning, I think.
Could also be a bad font, or something else. have you tried exporting to .idml yet? see http://forums.adobe.com/thread/526991
kestabrooks wrote:
I replaced the plug in. did an update and replaced the font. It seems to be working now. So basically (I think) that it was because I was copying a page from one document that had a different type of font into another document. It that a correct assumption?
Not necessarily. Font TYPE should not be an issue, but corrupt or badly made fonts can be a problem.
The optical kerning may be paer of a style definition, or it could be applied locally. For a style, you can edit the style to change the kerning method (or, if it's a character style that does nothing more than set optical kerning, remove the style). If it's applied locally you can use Find/Change to remove it. In the GREP tab search for .+ and open the Find Formatting dialog. Under Basic Character Formats set the kerning dropdown to Optical. Leave the change field blank, but open the Change Formatting dialog and in the same dropdown set the kerning to metrics.
Optical kerning is meant primarily for use with glyph pairs form diffent fonts or font styles to try to make them look better spaced. It really isn't a substitute for the built-in kerning in a font.
Peter is right on this ,, Font type cannoy be the cuase however how this font is used in the document,
You wrote :"I was copying a page from one document that had a different type of font into another document. It that a correct assumption?"
so may be when you copied and pasted the content , the text styling started giving the issues .....I think it will be teh guess work only to say what happened becuase we dont what exactly happened at your end with the document.
