PauletteP2
Planning Ahead for Using Boilerplates
Apr 9, 2012 2:09 PM
Tags: #proposals #boilerplate
Hi all,
I work as an RFP Response writer, creating proposals for companies seeking our products. What happens is that we get a Request for Proposal (RFP), which usually has requirements including questions to answer. There are also pages I use in nearly every proposal, including product description pages, executive profiles and a cover page. These mostly stay the same but need to be customized for each customer. What I'm thinking is that I will create Masters for each page I might use (one for each product they might want, company description, cover page). Then when I get a new RFP, I'll copy the main file, delete the masters I'm not going to need and tweak the masters I will need.
I'm noticing my file is getting quite large though and I'm wondering if this is the best way. I want to be a smart designer, but I have no experience so I could use all the advice I can get.
THANKS!!!
    Apr 10, 2012 3:11 AM   in reply to PauletteP2
    Pehaps a folder (or folders) of snippets (and a snippet can be an entire page of objects) would be easier to manage. You could just drag the the ones you need out of Bridge or Mini-Bridge onto your pages, then edit as necessary.
    Apr 10, 2012 3:35 AM   in reply to PauletteP2
    You can also try "Template" , prepare the template and then use it depending on your RFP , esay to maintain and customizable as well.
  • John Hawkinson
    Jun 25, 2009
    Apr 10, 2012 5:34 AM   in reply to PauletteP2
    I don't think there's anything wrong with this approach. Test and see if opening a copy of your template and Save As -ing drops the file size back down. It should, unless there's something weird.
    Which approach to use depends a lot on how you like to work, and all sorts of incidentals about your workflow.
    Apr 10, 2012 8:16 AM   in reply to John Hawkinson
    The size may be due to your file containing embedded graphics (graphics that aren't linked to their sources on a drive, outside the file.) \\
    * Consider linking graphics to reduce the file size.
    * You may want to consider using conditional text to show and hide content.
    * You may also want to consider using cross-references from the document you're building for a new RFP, to stored boilerplate paragraphs in one or more separate documents. Cross-references only bring in text, not graphics or tables, so this might not suit for all uses. Also, some folks report problems with the reliability of cross-file cross-references. One workaround is to convert the cross-references to text before finaliing the document.
    * You may also want to consider using Data Merge with a Data Source file that contains references to boilerplate stored in text and graphics files that are saved on disk. You can edit a generated merged document like any other InDesign document, so you can add personalized content manually.
    Search Google for terms like "InDesign cross-reference tutorial," "InDesign data merge tutorial," "InDesign linking graphic files tutorial," without quotes for details on these topics.
    HTH
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
