Basically, I want to align a row of images horizonally each with the same amount of space in between each. what would be the best way to go about this? should i put each one in a div tag?
I want them to look how images would be aligned in a clothing website. so for example, like this - http://shop.thehundreds.com/c-439-tees.aspx
thanks
Hi Hannah(?),
you could try one of Nancy O.'s templates from there: http://alt-web.com/TEMPLATES/CSS-Semi-liq-photo-sheet.shtml.
Hans-Günter
The site you link to does it in a table.
The site that hans-g points to uses CSS and each image is contained in a <p> element.
If you just want images and nothing else, you would not need another element. If you want to add captions then it would be better to use a containing element; a <div> if you like. The nice thing about Nancy's site is its flexibility.
Martin
Hi Hannah,
do you know how to use source codes? Please have a look at Nancy's website and put the code in a really new Dw file. For a first step you should delete all the things you don't need. Load it up to your server and come back with the link, no matter how your site looks like.![]()
Hans-Günter
