Hi all,
I work as an RFP Response writer, creating proposals for companies seeking our products. What happens is that we get a Request for Proposal (RFP), which usually has requirements including questions to answer. There are also pages I use in nearly every proposal, including product description pages, executive profiles and a cover page. These mostly stay the same but need to be customized for each customer. What I'm thinking is that I will create Masters for each page I might use (one for each product they might want, company description, cover page). Then when I get a new RFP, I'll copy the main file, delete the masters I'm not going to need and tweak the masters I will need.
I'm noticing my file is getting quite large though and I'm wondering if this is the best way. I want to be a smart designer, but I have no experience so I could use all the advice I can get.
THANKS!!!
I don't think there's anything wrong with this approach. Test and see if opening a copy of your template and Save As -ing drops the file size back down. It should, unless there's something weird.
Which approach to use depends a lot on how you like to work, and all sorts of incidentals about your workflow.
The size may be due to your file containing embedded graphics (graphics that aren't linked to their sources on a drive, outside the file.) \\
* Consider linking graphics to reduce the file size.
* You may want to consider using conditional text to show and hide content.
* You may also want to consider using cross-references from the document you're building for a new RFP, to stored boilerplate paragraphs in one or more separate documents. Cross-references only bring in text, not graphics or tables, so this might not suit for all uses. Also, some folks report problems with the reliability of cross-file cross-references. One workaround is to convert the cross-references to text before finaliing the document.
* You may also want to consider using Data Merge with a Data Source file that contains references to boilerplate stored in text and graphics files that are saved on disk. You can edit a generated merged document like any other InDesign document, so you can add personalized content manually.
Search Google for terms like "InDesign cross-reference tutorial," "InDesign data merge tutorial," "InDesign linking graphic files tutorial," without quotes for details on these topics.
HTH
Peter
_______________________
Peter Gold
KnowHow ProServices
