Lydia Kelly
PCG Error in Encore from Imported Premeire File
Apr 10, 2012 9:07 AM
Tags: #error #chapter #premiere_cs5 #sequence #import #encore #dvd #build #imported #premeire #pgc #abpgc
For each sequence in Premeire I was able to succesfully transfer to Encore.  For some reason, there is this one sequence that wont import.  I had imported all of the sequences at once, then seperated them, initually but I caught an error, so I went back into Premeire, fixed the problem, and then imported the sequence (only the sequence with the error) into Encore, just like I had with all of the others (MPEG-2-DVD).  I keep getting an error saying:Screen Shot 2012-04-10 at 11.56.22 AM.png
This error in encore will not go away when I try to create the DVD.  I have moved the chapter to other timelines, but still, I get this error wherever it goes.  How can I fix this?  Thank you!
    Apr 10, 2012 9:13 AM   in reply to Lydia Kelly
    I would test this by creating a new Encore project, import only the one problem sequence. Do you get the error?
    I suspect a problem in what you did to change it in PR.
