I don't know why, but just hitting a simple carrage return is giving me a coulumn break. I'm not sure how to make this stop?
Are you using a Windows laptop? There are a number of them that seem to map the numpad Enter and the alphapad enter together, and changing the stae of the NumLock toglles back and forth. If you have such a sytem, the only thing you can do is Edit > Keyboard Shorcuts... and remap the numpad Enter key to be a paragraph break, then create a new shortcut, if you want one, to replace the column break.
TwitchOSX wrote:
Yea, but if it works, it works =)
The point is it DOESN'T work if the keybord binds both keys together. First of all, you don't get a paragraph break, you get a force line break, which is not the same at all, and second, if the keys are bound tegether the numlock will toggle that back and forth between the forced line break and the frame break, just as without the shift it toggles paragraph return and column break. This is a BIOS problem, or perhaps a keyboard problem, and it cannot be "fixed" in ID, only worked around by editing keyboard shorcuts so both the regular and numpad enter keys are both assigned to the same tasks.
