So I just installed AE today and so my friend and i shot some test footage to edit but when I import it into the program and try to play it or preview it the audio is all mashed up and in the wrong place. When i press preview it plays the video all the way through but it pulls a piece of audio from the middle and mashes it up from there. Anyone ever run into similar a similar problem? Any help is much appreciated thanks.
AE is not suited for editing or really even for ingesting footage. You probably are shooting a highly compressed format. You should bring your footage into Premiere, using its capture functions, and then export it to a more suitable frame-based codec before attempting to use your footage in After Effects.
There's really no way to diagnose your situation. Here's a link to the information you need to provide that will help us help you:
http://forums.adobe.com/thread/961743
And since you' brand-new to AE, here's an EXTREMELY valuable place to spend some quality time:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after- eff.html
After Effects is not the kind of application you use for a couple of tricks and expect things to turn out right the first time. It takes a good knowledge of the AE basics to make it do what you want. Hence that second link.
As Dave says, we need more information.
I'm going to make a guess: You're using AIFF audio in After Effects CS5 and have not installed the bug-fix updates.
Start by installing the updates.
