Carriage return is giving me a column break.
Apr 10, 2012 9:03 AM
I don't know why, but just hitting a simple carrage return is giving me a coulumn break. I'm not sure how to make this stop?
    Apr 10, 2012 9:07 AM   in reply to OpheliaPDX
    Which "Enter" are you using...
    Numpad "Enter"--default keyboard shortcut is set for column break
    "Enter"--Carriage return
    Apr 10, 2012 9:20 AM   in reply to OpheliaPDX
    Are you using a Windows laptop? There are a number of them that seem to map the numpad Enter and the alphapad enter together, and changing the stae of the NumLock toglles back and forth. If you have such a sytem, the only thing you can do is Edit > Keyboard Shorcuts... and remap the numpad Enter key to be a paragraph break, then create a new shortcut, if you want one, to replace the column break.
    Apr 10, 2012 9:24 AM   in reply to OpheliaPDX
    Try holding Shift and hitting Enter or Return?
    Apr 10, 2012 9:25 AM   in reply to OpheliaPDX
    Reset your preferences:-
    forums.adobe.com/thread/526990
    Apr 10, 2012 10:23 AM   in reply to OpheliaPDX
    I think you'll find that Shift + Enter is a soft return (forced line break) or a frame break, depending on the status of the numlock.
    Apr 10, 2012 10:33 AM   in reply to Peter Spier
    Yea, but if it works, it works =)
    Apr 10, 2012 10:41 AM   in reply to TwitchOSX
    Until you try to apply paragraph styles, and what was intended to be two separate parapgraphs is seen as one, and can't be assigned separate paragraph styles.
    Apr 10, 2012 11:38 AM   in reply to TwitchOSX
    The point is it DOESN'T work if the keybord binds both keys together. First of all, you don't get a paragraph break, you get a force line break, which is not the same at all, and second, if the keys are bound tegether the numlock will toggle that back and forth between the forced line break and the frame break, just as without the shift it toggles paragraph return and column break. This is a BIOS problem, or perhaps a keyboard problem, and it cannot be "fixed" in ID, only worked around by editing keyboard shorcuts so both the regular and numpad enter keys are both assigned to the same tasks.
    Apr 30, 2012 1:50 PM   in reply to OpheliaPDX
    CTRL + ENTER  works!!   I'm using a PC, and control + enter key (either standard or the number pad enter key) work.  Silly but it works.
