hambone001
when I use spot or healing brush it works a little and then starts leaving dark smudges or lines
Apr 10, 2012 8:10 AM
Tags: #and #brush #spot #healing
The spot and healing brush seems to work a little, but then leaves dark smudges or even complete dark lines.  Also seems to pick up other objects in the picture as if it is copying a section of the picture.  Have tried to reset, but nothing works.
    Apr 10, 2012 8:17 AM   in reply to hambone001
    Could you please post a screenshot with the pertinent Panels visible?
    Have you checked the Tool’s Blend Mode (in the Options Bar)?
  • Noel Carboni
    Dec 23, 2006
    Apr 10, 2012 9:00 AM   in reply to hambone001
    The Spot Healing Brush in Photoshop CS5 uses Content Aware Fill, and it's function is EXACTLY to go find other parts of the picture to fill in over what you clicked on.  What is it that you expect it to do if not that?
    As Christoph has said, please provide some image examples.  It may be that it's not working correctly, but it's impossible to tell whether you're seeing it do what's expected without seeing the before/after results you're seeing.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 10, 2012 10:07 AM   in reply to hambone001
    Images don't make it back into the forum if they are attached to eMails.  You must use the web interface and the little "camera" icon to attach images.
    -Noel
    Apr 10, 2012 12:53 PM   in reply to hambone001
    For attaching screen-caps/Images, please see this ARTICLE.
    Good luck,
    Hunt
  • Noel Carboni
    Dec 23, 2006
    Apr 10, 2012 1:01 PM   in reply to hambone001
    I have been using the Spot Healing Brush a lot in the Photoshop CS6 beta, and it seems to be fine.
    -Noel
    Apr 10, 2012 10:30 PM   in reply to hambone001
    Don't have time to spend.
    If you don’t have the time to trouble-shoot the issue then why bother posting at all?
    People are trying to help you, but if you have an »I certainly did everything right«-attitude that might be difficult.
