i am getting an auth_error when trying to upload my website to business catalyst Again. it occured last week and then mysteriously work a day later.
I think some internal error was corrected at muse login or the site was down. is it down again. if you are shutting it down for maintenance, you need to let people know.
it
thanks in advance for your help
Lynn,
I understand what you are doing when you are receiving the error.
When you first activate Muse you enter an AdobeID. This same AdobeID account is used when connecting with Business Catalyst when publishing from Muse. If there is a problem/mismatch/synchronization issue with your AdobeID and Business Catalyst Account, you may receive this authentication error. Deactivating and reactivating has resolved this issue for other users: forums.adobe.com/thread/985495?tstart=0
Please follow the steps
...Copy link to clipboard
I'm having the same problem. An unknown authentication error..........
has this been addressed?
Thank you
Please try Deactivating and Reactivating Muse to see if this resolves the issue:
In Muse:
Best regards,
Corey
How can you deactivate if you can't connect??
lynn
Lynn,
You are receiving this authentication error when trying to Publish your site in Muse... so you are currently running in Muse, correct?
In Muse:
Once you have deactivated and reactivated Muse, try publishing your site again.
Best regards,
Corey
but only the software application is open. publishing or managing is the activity
that tries to connect to the web/ server application that is causing the error. it is not an error on launching muse application.
also get the error when trying to "manage" muse.
Lynn
Lynn,
Please follow the steps I outlined for deactivating and reactivating Muse.
Best regards,
Corey
Ok. Thank you.
lynn
Did this resolve the problem for you?
Yes. Thank you very much. If this is part of the update process, it should be included in the instructions.
Thanks again
lynn
It is not part of the normal Muse beta 7 update process - it's an error that a small number of users are encountering. We apologize for the inconvenience. Thanks for following up and helping to improve the Muse beta.
Just to say I hve had the same problem which your advice, Corey, sorted out.
Hi Corey, I am having similar issues as well!!
I cannot preview or publish, and continue to receive pop-ups. PLEASE, help --- I want to update my website!
best,
dd
Hi Corey I am having this problem and although I have tried your suggestion it still dose not work. I recently updated my AdobeID email address and it seems not to have been sync with BC. I can still see on the Partner Portal my old address but cannot change it. I have spent the last week (every day sending email back and forth, phoning with Adobe) and got this suggestion pasted to me last night. I thought Yes we have done it but it still doesn't work. Any other suggestions would be very much appreciated. I am now getting desperate for a solution.
All the best
Gary Proffitt
I'm having this SAME issue. I've followed the directions above...now it will not let me sign in. It won't access the server.
Can't build my new site fast enough; I still need this one to work.
Having the same problem here. Updated Muse to 2014.2.1, went to publish changes to business catalyst, and it come up with the error:80. I'm on a Mac, so I don't have 'Deactivate Muse' option, simply sign out of creative cloud, which I did, then shut down Muse. Reopened, signed back in, and same problem. Wasn't a problem until I updated to the newest version.
I am having the same issue, I updated my email and now it comes up with an error every time i try to publish the site. I have tried deactivating and restarting it also. any help would be greatly appreciated
So I had the same problem, but I fixed it in Adobe CC 2014
Step 1 - Help>Sign Out of user@email.com>Sign Out
Step 2 - File>Save
Step 3 - Force Quit Muse
Step 4 - Open Muse
Step 5 - Help>Sign In
Step 6 - Publish>Options>Publish To: Select the Business Catalyst Name (EVEN IF ALREADY SELECTED)
>Upload: Only Modified Files (EVEN IF ALREADY SELECTED)
Step 7 - Click OK and your done!
thanks for your instructions! they saved me from panic.
I had the same problem tonight. Though I dislike that it's a known issue still going on, thanks for posting frederick, so that I was able to find a thread with a clear solution. that fortunately worked. thanks, LJDezignz Nov 14, 2014 9:37 PM !
No problem! If you could click mark as correct beside my correct answer to make it easier for others when they visit, that'd be awesome!
Thank you very much, Corey. That issue was making me crazy. I appreciate you taking the time to answer!
