Install error - an action script error occurred
Apr 5, 2012 4:15 PM
I have OSX 10.6.8  When I try to install Muse, Beta 7 I get an error message -and action script error occurred
    Apr 6, 2012 3:41 PM   in reply to h00ver
    Could you post a screenshot of the error message?
    Apr 9, 2012 9:41 AM   in reply to h00ver
    Can you copy the text out of that alert? I'd like to see the entire stack.
    Apr 9, 2012 10:46 AM   in reply to h00ver
    Looks like Muse is encountering some problem writing a log file.
    If you switch to the Finder and choose 'Go to folder' from the 'Go' menu, and enter ~/Library/Preferences, like so:
    Do you have an 'AdobeMuse' folder in there? Is there anything in that folder?
    Do you have an 'Adobe' folder in there containing a folder named 'HeadlightsAIR'? Is there anything in that folder?
    Apr 9, 2012 3:04 PM   in reply to h00ver
    Maybe Muse can't write to the ~/Library/Preferences/Adobe folder. If you do a 'get info' on that folder in the finder, does your user account have read & write priviledge?
    Should look like so:
    Apr 10, 2012 11:03 AM   in reply to h00ver
    Your message didn't come thru - did you check the permissions on that Adobe folder?
    Apr 10, 2012 11:14 AM   in reply to h00ver
    Still didn't come thru - does your user show 'read & write' for that folder?
    Apr 10, 2012 1:11 PM   in reply to h00ver
    If you open the Terminal app from /Applications/Utilities, and type in this command:
    touch ~/Library/Preferences/Adobe/myNewFile
    What does the terminal window say? Is the file 'myNewFile' created in the ~/Library/Preferences/Adobe/ folder?
    Apr 10, 2012 1:44 PM   in reply to h00ver
    Yes, and then hit the return key to execute that line.
    If you can't write to that directory, you should see something like this:
    If you can write to that directory, you should see something like this:
    and the file should be created if you check that folder in the finder.
    Apr 10, 2012 2:28 PM   in reply to h00ver
    Ok, that's progress - for some reason you're not allowed to write to that folder. Let's figure out why.
    Type this into your terminal window:
    ls -ld ~ && ls -ld ~/Library/ && ls -ld ~/Library/Preferences && ls -ld ~/Library/Preferences/Adobe
    I want a screenshot of the result of that. Should look something like this:
    If you have trouble posting the screenshot here, you could email it to me at lbushore@adobe.com
    Apr 10, 2012 2:56 PM   in reply to adobelance
    Thanks for sending the screenshot. You've got some unusual permissions on that folder, which is preventing Muse from writing to it.
    Type this command into the terminal window to fix up the permissions, and you should be able to launch Muse:
    chmod 755 ~/Library/Preferences/Adobe
    Apr 10, 2012 4:02 PM   in reply to h00ver
    Just executing that chmod command should do it. After that try launching Muse again.
