VonBetelgeuse
Zenithink ZT ICS not compatible with photoshop touch?
Mar 10, 2012 3:54 AM
Tags: #photoshop #touch #incompatible #zenithink
Apparently google play says it is incompatible but I see no reason for this?
    Mar 10, 2012 12:54 PM   in reply to VonBetelgeuse
    Using a Motorola Xoom Wi-Fi model with ICS but don't have any problems.
    Apr 10, 2012 12:49 PM   in reply to Warunicorn
    I have the same problem
    Motorola Xoom
    This item cannot be installed on your device.
    is runing on ICS 4.0.4 and non of the adobe touch app will istall in my Xoom
    Any Idea?
    Apr 11, 2012 1:07 AM   in reply to Rifanos
    Exactly which Motorola Xoom do you have? It would also help to know in which country you're in.
    thanks,
    Ignacio
    Apr 11, 2012 5:30 AM   in reply to ibarrien
    Motorola Xoom Wifi 32GB and I located in Puerto Rico
    Apr 11, 2012 5:44 AM   in reply to Rifanos
    Could you maybe add some more information about model number?
    Have you tried to install it over Google Play in a browser or only over the device?
    Please let us know what Google Play over the browser tells you the same.
    Ignacio
    Apr 11, 2012 6:49 AM   in reply to ibarrien
    In the Divice just apear a error that the app not found and in the browser it say This item cannot be installed on your device.
    Model
    Brand
    MOTOROLA
    Model
    XOOM with Wi-Fi
    Operating Systems
    Operating System
    Android 4.0.4 ICS
    CPU Type
    NVIDIA Tegra 2
    CPU Speed
    1.00GHz
    Tech
    Dual Core Processor
    Display
    Screen Size
    10.1"
    LCD Features
    Touch Screen
    Light-Responsive Display
    Pinch to Zoom
    Display Type
    Wide XGA
    Resolution
    1280 x 800
    Graphics
    GPU/VPU
    NVIDIA ULP GeForce
    Hard Drive
    HDD
    32GB Flash
    Memory
    Memory
    1GB DDR2
    Communications
    WLAN
    802.11b/g/n Wireless LAN
    Bluetooth
    Bluetooth 2.0+EDR+HID
    Ports
    USB
    1 x Micro USB
    HDMI
    1 x HDMI
    Audio Ports
    1 x 3.5mm Headset Jack
    Input Device
    Keyboard
    Virtual Keyboard (Portrait and Landscape)
    Supplemental Drive
    Card Reader
    Supports microSD up to 32GB
    Webcam
    Rear camera: 5-megapixel camera with autofocus, dual-LED flash and digital zoom
    Front camera: 2-megapixel webcam
    Power
    Battery
    24 W-hr
    Battery Life
    up to 10 hours
    Apr 11, 2012 7:00 AM   in reply to Rifanos
    I assume that you upgraded it from HoneyComb - have you rebooted it at least once?
    thanks,
    Ignacio
    Apr 11, 2012 8:00 AM   in reply to ibarrien
    If you mean turn off and on Yes
    and yes was upgrade from HoneyComb to ICS
    Apr 11, 2012 10:27 AM   in reply to Rifanos
    What's the Android version, Kernel version and Build number? (Tap the Settings icon under Apps > "About tablet" on the left.)
    Take a screenshot of that screen by simultaneously pressing the "volume down" key and the power button. Upload it to your computer via any method like Dropbox or simply by connecting your Xoom to your desktop computer via USB. (The screenshots will, naturally, be in a folder called, "Screenshots.") Post it here.
    Apr 11, 2012 12:38 PM   in reply to Warunicorn
    Done
    Apr 12, 2012 9:08 AM   in reply to Rifanos
    You have the same exact build, etc., as I have. There really should be no reason why you can't get PS Touch on there; I have and use it with no problems. (However, that was before I upgraded to Ice Cream Sandwich but it runs just fine now.)
    As Ignacio mentioned, did you try installing PS Touch through Google Play (formerly Android Market) itself?
    Apr 13, 2012 5:06 AM   in reply to Warunicorn
    Yes I do and I keep getin the same mesage "The item you were attempting to purchase could not be found." this on google play itself!
    And in the browser say "this app is incompatible with all your divices."
    Apr 13, 2012 5:59 AM   in reply to Rifanos
    This sounds like a Google Play/Android issue.
    Do you have several id's connected to the device?
    Is this the only application that you cannot install?
    I've encountered a similar problem and if I remember it correctly a hardware reset made it (with a backup before).
    Ignacio
    May 8, 2012 8:30 PM   in reply to ibarrien
    I'd like to know if this was ever resolved by the OP. I have the same problem on a Honeycomb Galaxy Tab 10.1", however I strongly believe this is a Google issue and not a technical issue. Basically, they don't seem to support any purchasing of tablet apps for Puerto Rico. I can buy apps for my phones just fine, but nothing for my tablet.
