I have updated GPS coordinates using the new Map module but these are not output with the EXIF when I export JPGs.
I have ensured that Remove Location Info is unchecked.
I welcome any advice
regards
JWW001
As requested I attach screen shots of the LR4 metadata panel after I have updated the coordinates in LR4 and also the LR4 export dialog. Also a JPEG of the exported photo which still has the original coordinates untouched from the camera along with the EXIF coordinates. These are incorrect as the camera hadn't acquired the satellites. LR4 has successfully exported the copyright information.
regards, JWW001
OK, I can reproduce what you're seeing. It seems to be happening when exporting a JPEG file with updated GPS data as JPEG. Doesn't happen when changing GPS data on a Raw image and exporting it as JPEG (export contains updated information).
I would report it as a bug here.
Beat
For an original Raw I perform the same steps as for an original JPEG and again the changed coordinates are not written to the exported JPEG.
It is the JPEG export that doesn't write the new coordinates, it correctly writes the Copyright Info that I have input into the Metadata.
Save metadata to file, correctly writes the changed coordinates to the original file but I don't want to change the original file in any way.
John
