Relative file path/folder (AppleScript)
Apr 10, 2012 11:40 AM
Tags: #applescript #filepath
How do I set a folder as a realtive path to where the script is running??
is there any easy way like in unix, starting without / ?
or for example
"~/Desktop/"
"/users/<login>/desktop/"
seems that path to me is the only way...
is there an easy way to change posix paths to applescript??
I have this code:
tell application "Finder" to set templateFile to (container of (path to me) as string) & "Graficas FINAL ADQAT.ai"
with this error:
error "No se ha encontrado el archivo Macintosh HD:Users:Vibra:Desktop:Graficas FINAL ADQAT.ai." number -43 from "Macintosh HD:Users:Vibra:Desktop:Graficas FINAL ADQAT.ai"
the file is there how I change the filepath to be compatible with applescript??
    Apr 10, 2012 1:08 PM   in reply to macbeth07
    Do you just want…
    set MyFile to ((path to desktop) as text) & "Test.ai" as alias
    tell application "Adobe Illustrator"
      activate
      open MyFile
    end tell
    This also works if both files are at the same location…
    tell application "Finder" to set templateFile to (container of (path to me) as string) & "Test.ai" as alias
      activate
      open templateFile
    end tell
    AppleScript paths are HFS colon separated, most apps like to be passed an AppleScript alias specifier UNIX is POSIX paths a slash separated…
    Apr 10, 2012 1:50 PM   in reply to macbeth07
    no problem… the coercion to alias confirms the file exists… it should go inside a try and on error if you want to trap/handle errors…
