Which of these cards would be better suited for video editing:
Areca ARC-1882i
LSI 9265-8i
Both are approximately the same price and just in my price range. I will have four 1TB HDD's that I want to put in a raid array. Also assume either one will work with my X79 motherboard.
I know this thread is a few weeks old, but I think I will be getting the card soon. I almost bought the LSI because it has the CacheCade option, but I think I have decided to get the 1882ix-12 with extra cache memory instead.
Do you know if you need to purchase the 4GB memory stick from Areca or is it possible to get an 8GB stick. If the 8GB of memory is possible, will it even help?
Is there anything else I need to know before I buy this?
JobJoe,
I would suggest getting the "-4G" model card (1882ix-12-4G) that already has the 4GB RAM installed.
Regarding 3rd party RAM, I am not saying that it cannot work, but if you search the web you will find a lot of users that have tried 3rd party RMA with Areca's 1880 series (similar to 1882 series) and never gotten it to work properly.
Jim
I now have the 1882ix-12-4G installed and have 2 HDD's connected just to do some testing. This thing is even faster than I imagined. I plan to run AS SSD, ATTO, and Crystal Disk Mark to get a starting point. If anyone is interested, I may post those results here. I have run ATTO and ended up with reads of 2500 MB/s and writes of 3400 MB/s.
I plan to get 6 Hitachi drivers in raid, which should be even faster.
I have tried the free version of HD Tune in the past. I will have to try that again.
I just discovered that my Acronis imaging software does not see the Areca or the drives attached to it. What imaging software can be used that sees the Areca and can make image files and also be able to restore image files to and from the Areca?
Can someone help me with some HDTune results. The only difference between the two is a setting in the Areca settings. The drives are two WD 2TB drives in Raid0 that I am using for testing before I get the 6 Hitachi drives. The first image is using the default settings and the second one Is with Disk Write Cache Mode enabled. Note that the scale on the left is not the same.
JobJoe,
I can confirm that ShadowProtect Desktop Editon works great with Areca images for both backup and restore. I have even backed up a RAID OS/boot array from the Areca controller and restored it to a single drive connected to an Intel motherboard controller - how cool is that! It's insanely fast too; imaging my pretty fast RAID 0 boot/OS/programs array with 61GB only takes 2:36 minutes (23.3 GB/min, 279 MB/s, 2232 Mbits/sec). Note too that the affordable "Desktop edition" allows you to any drive on your LAN; I'm pretty sure that to do a restore with this version you can't restore from the LAN, however I've copied the restore image down to a USB hard drive (from the LAN) and then restored to a PC as "stand-alone".
Regarding the HD Tune Results your results are for all practical purposes the same; you can ignore the maximum read speed with the cache on (that's from the controller) for the purposes of benchmarking your drive speed. Regarding the scale difference, I find the "autoscaling" only annoying, but I'm not aware of a way to override it.
Finally, your WD 2TB's "tail off" (slow down) less than most rotating drives I've ever tested using HD Tune Pro; what is the exact model # and firmware version that you are using?
Jim
This wasn't in your list of choices, but for me, I'll never buy another controller card that's not an ATTO. You're going to see similar specs from many different manufacturers, but the difference with ATTO is the support. I bought an R680 card that started acting up after about three weeks. I called tech support, described my problem, and I had a new card on my doorstep at 8 AM the next morning.
Ask the company you plan to buy from if they cross ship an RMA. If they don't, expect to be out of business for at least three days, and expect to pay your own overnight shipping both directions.
I mistakenly bought a HighPoint Tech RocketRAID as my first controller card. It went bad, and it took THREE WEEKS to get a replacement. Oy!
Another option is to buy from a VAR that has great service after the sale, and maybe you can get an ATTO-like experience, if they have the same committment to customer satisfaction.
If these aren't important considerations, then please excuse me for butting in.
And Atto is the only one to support Raid4. Of course that is of little value is that is not the level you want. Back in the middle ages of raid controllers, they had a big corporate client that insisted on using raid4 and since that time they are the only manufacturer to include that raid level.
JobJoe wrote:
Jim Curtis: I have already purchased the ARC-1882ix-12-4G and think it works quite well for my purposes.
My HPT card worked quite well for a while, too. But, you've already read my sob story about that. I wish you continued success with it.
Harm, ATTO has yet another RAID level... DV RAID. Yet, nobody seems to be endorsing its use for video, even though it was specficially designed for it. RAID 5 is still the choice of four out of five doctors, with RAID 6 as a fallback for the risk-averse.
