Adobe reader has stopped working
Mar 28, 2012 5:28 PM
Tags: #adobe_reader
Just got a new computer running Windows 7 and downloaded Adobe Reader 10.1.2 version and get this message:   Adobe Reader has stopped working...
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I have tried uninstalling and reinstalling and the same.  I have also tried the repair option and nothing. Any other ideas?
    Apr 2, 2012 9:09 AM   in reply to MEMRY
    Please see if the solution posted in the KB article below works for you:
    http://kb2.adobe.com/cps/928/cpsid_92870.html
    Apr 11, 2012 12:09 PM   in reply to MEMRY
    I am having the exact same problem on a new HP laptop running Windows 7.  Adobe Reader won't even open.  I can't view documents, let alone print (which the above suggestion seems to be regarding).  I tried repairing the pre-installed version of Adobe X, uninstalling it, and reinstalling from a freshly downloaded version.  Nothing.  Same error message...  Any help would be appreciated.
    Follow-up:  I found the page that allows you to choose which version you want to download rather than having it auto-detect which one.  It offered version 9 as well as 10 for Windows 7.  I tried version 9 and it seems to work.  Not a real fix, but a good temporary one that doesn't require any 'hacking'.  Just thought I'd share this finding in case it helps someone else.  I hope it's only temporary, though.  I'd still really like to be able to use the most current version...  (hint, hint, to Adobe or Windows folks, whoever need to make the changes...)
    Apr 18, 2012 4:57 AM   in reply to IDMom
    Please try and install the latest version of Reader (i.e. version 10.1.3) from http://get.adobe.com/reader
    Is the issue still existing with Reader 10.1.3 as well?
    If it does, please let me know the following details:
    1. What is the exact error message that you are receiving. Please post a screenshot of the same if possible.
    2. Which Antivirus software are you using? Does disabling the Antivirus software temporarily help?
    3. in your knowledge do you have any 3rd party plug-ins installed for Reader X?
    Apr 22, 2012 2:25 PM   in reply to Ankit_Jain
    Yes, I'm getting the same error with 10.1.0 MUI that was pre-installed on
    my new machine and with 10.1.3 from a current download.  Yes, I uninstalled
    and restarted between installations.
    1)  Error message (in a small window):
    Windows is checking for a solution to the problem...
    Then nothing happens - no follow up message and the program does not open.
    2)  Disabling the antivirus does not help.  I was actually running with no
    antivirus at all the first time I got the error.  I have not been able to
    get any version of Acrobat X to run on this machine under any conditions.
    Once i tried to do a repair and it tried to run in Win XP compat mode.
    Even that failed.  (Sorry, I didn't write down that error message but it
    had to do with not being able to open in safe mode.)
    3)  I am not aware of any 3rd party plug-ins installed.  As I mentioned
    above, I have not ever been able to get it open so anything there is would
    have been pre-installed from the factory.
    I'm running an HP Pavilion dv7 with Windows 7 SP1 and it has been
    installing updates constantly so all updates should, hypothetically, be
    there from Microsoft.
    The only solution I've found so far is to go back to Reader version 9.5.1
    which will install properly and open.
    Note:  Every installation attempt with any version of Adobe Reader has said
    it was a successful install.  Versions of X just won't open...
    Thanks for your help.  Hopefully this issue gets resolved quickly.
    Apr 23, 2012 12:00 PM   in reply to MEMRY
    I have the same problem can't get reader to work at all on windows 7........nothing seems to work
    Jun 18, 2012 11:55 AM   in reply to MEMRY
    Thanks, I'll try that
    [auto-quote removed by host]
    Thank you...looks like that worked
    Jun 13, 2012 8:31 AM   in reply to Ankit_Jain
    I have uninstalled and reinstalled 3 times. I ran a C Cleaner, registry cleaner, I am running Windows 7 and everything seems to be working. In Google Chrome when I try to open it just is a never changing grey page with the circle arrow. In IE 9 it say Adobe reader has stopped working, windows searchig for a soluion. Then it tells me that it is working fine. Well it's not because I cannot open any.pdf files. I cannot open them from file explorer either. I get an error every time saying Adobe reader has stopped working. When I try to open Adobe reader it does not open but immediately says it has stopped working? I have restarted computer, reinstalled? Now what? Please help!!!!!
    Jun 18, 2012 6:01 AM   in reply to MEMRY
    I finally did this and now am running version 9.5 and it seems to be working just fine again. Thanks!
    Aug 10, 2012 9:05 AM   in reply to IDMom
    Great! What was the page to install Reader version 9? Would you mind sharing the URL? Thanks!
    Aug 10, 2012 9:50 AM   in reply to brandoCalrissian
    May 17, 2013 7:51 PM   in reply to Ankit_Jain
    Still getting the error windo with this info:
    Windoes never closes the program ... no a solution never comes.
    HELP!
Bookmarked By (1)
