Migrating Hot Keys to CS6
Mar 28, 2012 3:03 PM
Title says it all. I fould the Keyboard Short Cut file in CS5 and when I went to CS6, I found a folder for it, copied the file from CS5 . It didn't work.
Is there a method for doing so?
Win 7 64.
    Mar 28, 2012 7:13 PM   in reply to Hudechrome
    Hi Hudechrome,
    Make sure you're pasting them into the same roaming directory but for CS6. That worked for me anyway. You might also be able to save a set from the CS5 interface, but change the directory from CS5 to CS6.
    regards,
    steve
    Apr 10, 2012 3:52 PM   in reply to Hudechrome
    Hi Hudechrome,
    Sorry, I don't understand what your running into. I assumed you had a custom Keyboard Shortcut file that you wanted to transfer from CS5 to CS6. Is that not the case? If you are talking about the default Keyboard Shorcuts file, there is a size difference. I don't undrestand why you'd want to replace the default CS6 file though?
    regards,
    steve
    Apr 11, 2012 12:28 PM   in reply to Hudechrome
    Thanks for the further explanation. Have you tried loading your CS5 custom KBSC and then create a new set out of CS6? When I quickly did this with little customization, my custom .kys file went from 4K to 15K. I'm not sure if the file size change is due to added entries or the way we are saving the CS6 data compared to CS5 data.
    A quick look at the differences between CS5 and CS6 defaults shows these additions in CS6:
    Find Layers: Alt+Shift+Ctrl+F
    Adaptive Wide Angle: Shift+Ctrl+A
    Render: Alt+Shift+Ctrl+R
    regards,
    steve
    Apr 11, 2012 3:30 PM   in reply to SG...
    The shortcut file format is different in CS5 and CS6:  that's why the size changed.   CS6 moved to XML, so the file is much larger.
