1
Create a new digital ID - passwords do not match
Guest
Mar 26, 2012 Mar 26, 2012
When creating a new digital ID in Adobe Acrobat X on Windows 7 computer, after entering the new filename where the ID is to be stored and password, I get a message box: "Passwords do not match".
I have gathered the following information about creating digital IDs in Acrobat:
Acrobat help which says: "Type a password for the digital ID file. For each keystroke, the password strength meter evaluates your password and indicates the password strength using color patterns. Reconfirm your password."
A forum post which says: "6. Now enter the password in two places as instructed. "
I also watched a video how the person was inserting the password when creating a new digital ID, she had two text boxes to enter it. Screenshot from the video is here:
But when I try to do the same, I only have one field to enter the password. Here is a screenshot from my computer after clicking "Finish":
Does anybody know how to make the second password field appear, so I can confirm it and get rid of the "Passwords do not match" message and finally create the digital ID?
Security digital signatures and esignatures
43.0K
New Here , Apr 10, 2012 Apr 10, 2012
I just had the same problem, I'm using Acrobat X Pro.  I found this post and how the form is supposed to look so when I had typed in my password in the "Password:" box, I pressed Tab and the cursor dissapeared, I then re-typed my password assuming that it had gone to the "Confirm Password:" box that is not visible and then pressed Finish.  This worked for me and I was able to create a digital ID. Might work for you too.  Good luck.
May 02, 2018 May 02, 2018
Just had the same problem using Acrobat X Pro (10.1.16) on A 64-bit Windows 7 Pro installation. Thanks for posting the solution. I tabbed and re-entered my password and it worked great!
Adobe Employee ,
Apr 11, 2012 Apr 11, 2012
Can you please provide the following information so that the reason for such issue can be figured out:
1. Version of Acrobat?
2. OS: which service pack and 32bit/64bit
3. Screen resolution of display information. For it go to run -> type "dxdiag". Please share the scrrenshots of 'Display', 'System' tab.
Thanks in advance.
1. Version 10.1.3
2.
3.
Hope this helps,
Fish
Adobe Employee ,
Apr 12, 2012 Apr 12, 2012
Thanks for the information. We are looking into the issue from our end.
May 20, 2012 May 20, 2012
I had the same problem.
Apparently the second box exists but not visible due to broken dialog layout!
I could do the same trick:
  • enter first password in the visible box,
  • then click TAB key,
  • enter password again (into some obscured box),
  • then click Finish.
Guest
In my case it is 10.1.2
I have Win 7 Premium x64 SP1
Resolution 1920x1080
Screen DPI 120 DPI (the setting in Win 7 is 125% of "normal" font size which is 96 DPI)
By the way, after changing DPI to normal (96) both password fields are visible. So there is problem with compatibility with Windows accessibility settings.
Aug 09, 2012 Aug 09, 2012
I can confirm this is still an issue.
  1. Acrobat X 10.1.3
  2. Windows Vista Business SP2 64-bit
  3. Dual monitors at 1600x1200 resolution
I can get around this problem by hitting Tab and entering the password again.
May 30, 2018 May 30, 2018
Just wanted to confirm this is still an issue.  Thank goodness I found this thread!  I am using Windows 10.
Oct 10, 2018 Oct 10, 2018
Still an issue I had today. The Tab solution worked i.e. type password, hit the Tab key, type password again even though the original window still shows the ******** for the pass word.
Contributor ,
Oct 12, 2012 Oct 12, 2012
This is a bug, because of the programmer use abosulte layout for the dialog.
And the dialog only can work correctly with the default DPI settings of windows display.
Try goto windows control panel => Adjust Screen Resloution => Make text and other items larger or smaller => smaller (100% default)
Then logoff windows and logon, do all again, you can see the second password input box.
My environment:
Windows7 64bit
Acrobat X Pro
Oct 28, 2014 Oct 28, 2014
This bug still hasn't been fixed (I've just noticed the date on previous posts -- March 2012!
Come on, Adobe devs and project managers, extricate a digit and move this user story to the top of the product backlog!
As a user, I'd like to be able to see the second password field when creating a new digital ID, just like Annamarie Lukes does at 3 mins 20 in the digital ID tutorial video on the Adobe website: How to Digitally Sign a Document with Adobe Reader | Acrobat X | Adobe TV).
PS: Adobe Acrobat X Pro (v.10.1.1) with Windows 7 Home Premium SP1.
If it will be fixed, surely it won't be fixed in version 10 now version is 11 is out. Can anyone confirm if it is fixed in 11?
Mar 20, 2015 Mar 20, 2015
Thank you so much dtfish78dtfish78
I find it hard to believe that Adobe couldn't send out an update in 2 years to fix this issue so you could see both password boxes!
Advocate ,
Mar 23, 2015 Mar 23, 2015
I saw posts on this forum that this problem has been fixed in some recent Acrobat/Reader X and XI versions. Try the latest one (10.1.13/11.0.10).
