Watermarking problem in LR4.1RC
Apr 8, 2012 11:00 AM
I have working watermarks in LR4 that have been imported from LR3.
Today I made a logo in black & white.
Size 160kB in PNG to have it to be transparent.
When I try to use the logo it seems great in the graphic setup.
When I save the preset it doesn't come up with the name of the saved preset.
I also tried the same with my older PNG's that works in the presets made in LR3
Same problem, it will not show up as a saved preset.
Anybody that have experienced the same problem?
Is there any solution?
    Apr 8, 2012 2:57 PM   in reply to ArcticShooter
    Works on my Macbook 10.6.8 as expected and as in LR 3.x.
    What OS are you using?
    Apr 8, 2012 4:20 PM   in reply to ArcticShooter
    I would be suspicious of the PNG file since it is newly made. Mind posting it for a test?
    Apr 9, 2012 2:19 PM   in reply to ArcticShooter
    I know you are going to hate me but, it worked here.
    Created a new watermark with your BW PNG and saved as a preset. Worked
    Modified by increasing the logo size and was able to update the existing preset. Worked.
    Go to Export, I am able to select it.
    Step me through your Watermark creation carefully and lets see if we can figure it out.
    1. Will it save as a new WM Preset?
    2. If you modify will it let you Update Existing Preset with Current Settings?
    It should then appear in your list in Export, Print, Web???
    Apr 10, 2012 11:12 AM   in reply to ArcticShooter
    In order this is what I would check for (assuming you haven't done these already):
    1. Bad Preferences File
    2. User Permissions (assuming you have Admin access)
    3. Corrupt User Profile
    Apr 11, 2012 1:45 PM   in reply to ArcticShooter
    I am betting on number 3 from my previous post.
    Apr 11, 2012 2:24 PM   in reply to ArcticShooter
    Glad it worked. Sorry for the work you have ahead of you too!
