Thanks for your answer to me, for my bad english, I have a problem, may not easily answered.In multiple instances, limiting the maximum number of connections for the same IP?You give me the answer is to limit a single instance, whether there is a way to limit the number of users of the entire connected to the FMS?
c:\Program Files\Adobe\Flash Media Server 4.5\conf\_defaultRoot_\_defaultVHost_\Vhost.xml
<ResourceLimits>
<!-- Max number of clients that can connect to this vhost when running as local. -->
<!-- enforced by License key -->
<MaxConnections>-1</MaxConnections>
</ResourceLimits>
or if you have multiple vhosts, then adjust the path. I think this is what you are looking for. You can also control this number with server-side code:
http://help.adobe.com/en_US/flashmediaserver/ssaslr/WS5b3ccc516d4fbf351e63e3d11a11afc95e-7edfSSASLR..... Look for entries application.clients.and/or application.rejectConnection.
Thank you,But this seems to be to limit the maximum number of connections, I need the maximum number of connections in the same IP, this seems to limit the number of connections, is not it?
You mean you want to limit a connection from a user having the same IP? In other words, only one user coming from one IP can connect to your app?
YES,Thank you.In multiple instances,Single instance has been resolved http://forums.adobe.com/thread/988006?tstart=0,but In multiple instances I Feeling very difficult to resolve
At FMS side, store client's IP address information from connection request, and get total no of instances are connected to server from the every IP address.
