SOLVED
Cannot start JdbcService
Avatar
Level 2
ADEP, Document Services 10.0,  Windows Turnkey Installation.
JDBC is stopped an won't allow me to restart it at the ADMINUI.
I checked the logs and no errors I can see. I have restarted Livecycle/Jboss. Rest of system working fine
Any ideas or things to check ?
thanks
1 Accepted Solution
Avatar
Correct answer by
Level 2
This problem was fixed following a re-installation of the livecycle software.
Avatar
Employee
  1. Go to Home > Services > Applications and Services > Service Management
  2. Select JdbcService : 1.0
  3. Click Start
  4. Now check server logs for the error. What is the error?
Avatar
Level 2
The screen message is :  ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
The log is...
2012-04-23 15:23:15,087 ERROR [org.jboss.ejb.plugins.LogInterceptor] (http-0.0.0.0-8080-4) RuntimeException in method: public abstract java.lang.Object com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterLocal.doBMT(com.adobe.idp.dsc.transaction.TransactionCallback) throws com.adobe.idp.dsc.DSCException:
java.lang.IllegalStateException: Component: com.adobe.livecycle.JDBC version:10.0.0.0.20110711.1.289815 must be in a running state prior to starting service: JdbcService version: 1.0
    at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.start(ServiceRegistryImpl.java:1930)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
    at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
    at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
    at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
    at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
    at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTransactionBMTAdapterBean.java:197)
    at sun.reflect.GeneratedMethodAccessor694.invoke(Unknown Source)
    at org.jboss.invocation.Invocation.performCall(Invocation.java:386)
    at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:233)
    at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:156)
    at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
    at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
    at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:173)
    at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
    at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:173)
    at org.jboss.ejb.plugins.SecurityInterceptor.process(SecurityInterceptor.java:228)
    at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:211)
    at org.jboss.ejb.plugins.security.PreSecurityInterceptor.process(PreSecurityInterceptor.java:97)
    at org.jboss.ejb.plugins.security.PreSecurityInterceptor.invoke(PreSecurityInterceptor.java:81)
    at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
    at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
    at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:650)
    at org.jboss.ejb.Container.invoke(Container.java:1092)
    at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:436)
    at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
    at $Proxy258.doBMT(Unknown Source)
    at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:95)
    at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
    at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
    at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
    at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:165)
    at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
    at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
    at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
    at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:93)
    at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:225)
    at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:66)
    at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
    at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryClient.java:996)
    at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryClient.java:991)
    at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.start(ServiceRegistryClient.java:632)
    at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(StartServiceConfigurationsAction.java:110)
    at com.adobe.repository.ui.aac.struts.actions.CommandProcessorAction.execute(CommandProcessorAction.java:228)
    at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
    at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
    at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
    at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
    at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:86)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
    at com.adobe.repository.ui.aac.AacServletFilter.doFilter(AacServletFilter.java:137)
    at com.adobe.framework.SecurityFilter.doFilter(SecurityFilter.java:206)
    at com.adobe.framework.SessionBundleFilter.doFilter(SessionBundleFilter.java:135)
    at com.adobe.repository.ui.aac.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:76)
    at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
    at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:183)
    at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:95)
    at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
    at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
    at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
    at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
    at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
    at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:451)
    at java.lang.Thread.run(Thread.java:662)
2012-04-23 15:23:15,091 ERROR [com.adobe.repository.ui.aac.struts.actions] (http-0.0.0.0-8080-4) failed.to.start.service
2012-04-23 15:23:15,093 ERROR [com.adobe.repository.ui.aac.struts.actions] (http-0.0.0.0-8080-4) aac.action.unknownerror
com.adobe.repository.ui.aac.AacException: ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
    at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(StartServiceConfigurationsAction.java:133)
Thanks for looking at this.
Let me know if you need any more details ...
Avatar
Level 2
Hi, Some additional information which may be of use I have 2 ES3 installations :
The first installation is behaving correctly, the second installation is the one where JDBC will  not start.
There are minimal differences but I will llist them in case any are relevant -
Installation 1  ( good) >
Windows 7  Full turnkey istallation to C:
Installation 2  (broken)  >
Windows Server 2008 R2 6.1,   Installed options -  ProcessManagement
ReaderExtensions
Foundation
Forms
Turnkey Installation to E:
thanks again for any help
Avatar
Correct answer by
Level 2
