4hya
Can't set opacity to 100% using numpad
Apr 11, 2012 1:54 AM
as you can see in the following screenshot, the opacity of the layer is 55%, when I tried pressing 100 on the numpad,
it only goes to 10%, which is I want to make it 100%, 99% is doable, yet, I need 100% without clicking my mouse,
pressing 100 on the numpad works on the earlier versions of PS
is there any workaround here?
    Apr 11, 2012 11:43 AM   in reply to 4hya
    You could use the number keys on the keyboard (the ones above the letters), not the numeric keypad.
    Press zero for 100% opacity and tap zero twice for zero opacity.
    (the numeric keypad doesn't work for me ether on win8 cp using the zero key in cs6 because apparently win 8 uses that zero key on the numeric keypad for the logout screen)
  • Trevor.Dennis
    May 24, 2010
    Apr 11, 2012 4:29 AM   in reply to 4hya
    It's working for me, and I didn't need to type at all quickly.  I've never thought to use the number pad, but it actually makes a lot of sense.  For instance you can type 01 for 1% - you don't need to start with the full stop.
