Pdf Transparency problem
Apr 11, 2012 3:28 AM
hello indesigners.
i printed out a pdf,and had some pngs inluded in the document.
when it was printed out,some of the png icons came with a black rectangle around them.what went wrong?
im trying to find the appropriate settings for my pdf to avoid such an issue in future.
thank you.
    Apr 11, 2012 4:34 AM   in reply to inquestflash
    Not enough information....
    What did they look like in ID in Overprint Preview?
    You printed to PDF, or exported? What settings?
    Apr 12, 2012 2:32 AM   in reply to inquestflash
    I'm trying to figure out if you flattened transparency when you exported to PDF, so I need to know what the compatibilty setting was, or the preset, and whether the simulate overprint box was checked. What application was used to view/print the PDF?
  • Rob Day
    Oct 16, 2007
    Apr 12, 2012 3:36 AM   in reply to inquestflash
    PNGs with transparency can be problematic if they are resampled on export. Try resaving them as PSDs. Check this thread:
    http://forums.adobe.com/message/4316727#4316727
    Apr 12, 2012 4:34 AM   in reply to inquestflash
    See Rob's response... There's nothing in the transparency handling itself that should be causing this.
  • lilia@
    Jan 31, 2012
    Apr 17, 2012 12:59 PM   in reply to inquestflash
    pdf 1.4 is flattened... try version 7 (1.6) or later (if memory serves me right)
    Apr 17, 2012 1:14 PM   in reply to lilia@
    1.4 exported from InDesign is NOT a flattened PDF.
    Bob
  • lilia@
    Jan 31, 2012
    Apr 17, 2012 2:40 PM   in reply to Bob Levine
    ok... thats when not flattening started... knew i should have kept my mouth shut until i was at work lol... sorry about that
