EDoner
Cannot create a digital ID/signature
Feb 27, 2012 3:58 PM
Tags: #password #signature #digital_id #signature_password
I tried in vain to create a digital signature to enable me to sign and authorize a pdf doc today. With each attempt Adobe Acrobat Pro 10.1.2 asks for a digital file (defaults to a path of it's choosing) and a password.  I have no idea which password it wants.  No matter what I enter I get the same message: "Passwords don't match"  Don't match what??
I spent over an hour with Tech Support Chat rep who commandeered my desktop and largely accomplished nothing.
    Mar 1, 2012 5:14 AM   in reply to EDoner
    Hi EDoner,
    You might have given the password at the time when you created the digital signature.
    If you have forgotten the password, then you can create new digital signature and this time make sure to remember your password or write it somewhere.
    To create new digital signature do the following:
    1. While you want to apply your digital signature, it provides you a "Sign Document" dialog which has a "Sign As" dropdown list at the top in which your previous digital signature appears by default" and below it there is a "Password" field.
    2.You should select "New ID..." from the "Sign As" dropdown list and it will open a new window "Add Digital ID"
    .Select the Radio button " A new Digital ID I want to create now" and click next.
    3. Now select the radio button "New PKCS#12 Digital ID file" and click next.
    4. Enter the required details and follow the actions to complete the process and click next/Ok.
    5.Now it will ask you the location to store new Digital signature file (.pfx file, default path selected is like : "C:\Documents and Settings\username\Application Data\Adobe\Acrobat\10.0\Security\ " you can also change this location if you like by clicking at the "Browse".
    6. Now enter the password in two places as instructed. (This time write it somewhere so you dont forget ).
    7. Now onward you can use this digital signature for signing the files.( If you have more then one digital signatures then you will have to select this one from the Sign As dropdown list mentioned in 1st step while applying signatures.)
    You can delete your old digital signature file (.pfx file) whose password you have forgotten, this will also be in the same default location, if you had not changed the path during creation of that digital signature.
    I hope this information will be helpful.
    Thanks.
    Mar 27, 2012 10:19 AM   in reply to EDoner
    The problem with the answer given below is that it doesn't address the true problem.
    The error in Adobe's programming on this page for some users is that what is addressed above is that you cannot enter a password because there is only ONE place that appears....there isn't two visible places that the user can match.
    To get around this, first enter your password in the box you can see (first box).  Then the work around is that you enter the TAB KEY.  This will put you into the next box (that you can't see) and you will re-type your password blindly.  Make sure that you are typing it in exactly as the first as you are typing in the proverbial ether.   Hit the 'accept' button (or enter or whatever the OK button is for the page--sorry, i don't have the exact reference in front of me--but i think this part is self-explanatory) that you can see.  Hope this helps.
    Jack
    Apr 11, 2012 4:16 AM   in reply to tacitimagination
    Can you please provide the following information so that the reason for such issue can be figured out:
    1. Version of Acrobat?
    2. OS: which service pack and 32bit/64bit
    3. Screen resolution of display information. For it go to run -> type "dxdiag". Please share the scrrenshots of 'Display', 'System' tab.
    Thanks in advance.
    Feb 24, 2013 12:42 PM   in reply to tacitimagination
    Wow, thanks for this!  I've created a million Digital IDs, and couldn't for the life of me figure out why it was telling me my password didn't match when I hadn't created on on this computer yet.  I just hit tab (realized you must be right because the cursor clearly shifts focus, but isn't visible), entered the same password again, hit tab and voila.
    Thanks again!
    Feb 24, 2013 12:47 PM   in reply to Nikhil.Gupta
    1. Adobe Acrobat X Pro
    2. Windows 7, SP 1, 32-bit
    3.  see below
    Mar 8, 2013 1:21 PM   in reply to tacitimagination
    Right on the money!  Just as explained, it worked as it should.  This, after I was about to call Adobe and ask what was I doing wrong.  There should be an upgrade for this!  Thank you brother for the peace of mind you brought.
    Mar 20, 2013 12:55 PM   in reply to bmanonthego
    This happens on small screens with some resolutions when the bottom part of the dialog with the second (re-enter) password field just drops off and is invisible.
