Can I use the current add-ons I have for CS5.5 extended?
Apr 11, 2012 7:14 AM
Can I use the current add-ons I use with CS 5.5 extended with the beta version of CS6 beta?
    Apr 11, 2012 7:54 AM   in reply to drnoel7984
    What add-ons are you wanting to migrate? Plug-ins should work, with the caveat that the Mac version is 64-bit only for CS6. So if you were running the 32-bit of CS5.5 with a 32-bit plug-in, then that won't migrate. Panel extensions might need a small modification. Scripts should work unless they specifically target CS5.5.
    Are you having problems, or just trying to research before trying the beta build?
    regards,
    steve
    Apr 11, 2012 8:14 AM   in reply to drnoel7984
    Here's a FAQ about plug-ins that you might want to check out: http://forums.adobe.com/message/4221311#4221311
    regards,
    steve
