I have a document that contains some text that I want to copy to another document. The original text is tagged with a paragraph style called Body. If the document that I'm copying into already has a paragraph style called Body defined, then when I copy the text into this document, it applies its Body paragraph style to the text I'm copying into it. Is there a way to copy the text and maintain the text styling from the original document (overriding the paragraph style in the receiving document)?
I am using InDesign CS5.
Thank you for your reply, but that doesn't seem to be doing anything for me.
In document 1, I have a paragraph that is tagged with style Body that is Arial-Narrow, 16 pt. font size and 21 pt. leading. In document 2, there is a style Body in the paragraph styles list; it is Arial-Narrow, 9 pt. font size and 9.5 pt. leading. I selected the entire paragraph in document 1. I click in a text frame in document 2. Whether I choose Edit > Paste or Edit > Paste without Formatting, the resulting paragraph in document 2 is Arial-Narrow, 9 pt. font size and 9.5 pt. leading.
You will achieve your goal by just using basic Edit > Paste but you should try putting it in an empty, new text box. It keeps the appearance and will override your Body style leaving a + next to it. I advise you to create a new style with this though especially if you're later sending it to print.
If it's not doing that, you may have character styles applied.
I selected the paragraph in document 1. I chose Break Link to Style in the Paragraph Styles palette. I clicked in the text frame in document 2 (which only contains one empty paragraph that is CenterAlign, Arial-Narrow, 7 pt. font size and 7.5 pt. leading) and chose Edit > Paste without Formatting. The paragraph ends up formatted like the empty paragraph that was in that text frame to start with (7 pt. Arial-Narrow, centered), which is not what I want either. The copied paragraph is 16 pt. Arial-Narrow, LeftAlign in document 1 and I want it to end up that way in document 2.
