Hi there,
I'm loading a bitmap with FileReference.load() and than dump the byteArray into a Loader object and than add that loader object to stage.
The problem is that regardless if I load the loader into a Sprite or add it to the stage, neither the loader or the sprite don't have width or height. It's always 0. So I can't scale the image as I don't know it's dimensions.
Does anyone had this problem before and found a solution?
Thank you!
this code works
package
import flash.display.Loader;
import flash.display.LoaderInfo;
import flash.display.Sprite;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.net.FileFilter;
import flash.net.FileReference;
import flash.text.TextField;
import flash.text.TextFieldAutoSize;
public class Main extends Sprite
private var fileRef:FileReference;
public function Main():void
if (stage)
init();
else
addEventListener(Event.ADDED_TO_STAGE, init);
public function init(e:Event = null):void
removeEventListener(Event.ADDED_TO_STAGE, init);
fileRef = new FileReference();
stage.addEventListener(MouseEvent.MOUSE_DOWN, onDown);
var txt:TextField = new TextField();
addChild(txt);
txt.autoSize = TextFieldAutoSize.LEFT;
txt.x = txt.y = 20;
txt.text = "click anywhere to load an image file...";
private function onDown(evt:MouseEvent):void{
fileRef.browse([new FileFilter("Images", "*.jpg;*.gif;*.png")]);
fileRef.addEventListener(Event.SELECT, onSelected);
stage.removeEventListener(MouseEvent.MOUSE_DOWN, onDown);
private function onSelected(evt:Event):void{
fileRef.addEventListener(Event.COMPLETE, onLoaded);
fileRef.load();
fileRef.removeEventListener(Event.SELECT, onSelected);
private function onLoaded(evt:Event):void{
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onComplete);
loader.loadBytes(evt.target.data);
addChild(loader);
fileRef.removeEventListener(Event.COMPLETE, onLoaded);
private function onComplete(e:Event):void
var loaderInfo:LoaderInfo = e.target as LoaderInfo;
loaderInfo.removeEventListener(Event.COMPLETE, onComplete);
var loader:Loader = loaderInfo.loader;
trace("loader size: ", loader.width, loader.height);
