Hi there,
I'm loading a bitmap with FileReference.load() and than dump the byteArray into a Loader object and than add that loader object to stage.
The problem is that regardless if I load the loader into a Sprite or add it to the stage, neither the loader or the sprite don't have width or height. It's always 0. So I can't scale the image as I don't know it's dimensions.
Does anyone had this problem before and found a solution?
Thank you!
this code works
...package
import flash.display.Loader;
import flash.display.LoaderInfo;
import flash.display.Sprite;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.net.FileFilter;
import flash.net.FileReference;
import flash.text.TextField;
import flash.text.TextFieldAutoSize;
public class Main extends Sprite
private var fileRef:FileReference;
this code works
package
public function Main():void
if (stage)
init();
else
addEventListener(Event.ADDED_TO_STAGE, init);
public function init(e:Event = null):void
removeEventListener(Event.ADDED_TO_STAGE, init);
fileRef = new FileReference();
stage.addEventListener(MouseEvent.MOUSE_DOWN, onDown);
var txt:TextField = new TextField();
addChild(txt);
txt.autoSize = TextFieldAutoSize.LEFT;
txt.x = txt.y = 20;
txt.text = "click anywhere to load an image file...";
private function onDown(evt:MouseEvent):void{
fileRef.browse([new FileFilter("Images", "*.jpg;*.gif;*.png")]);
fileRef.addEventListener(Event.SELECT, onSelected);
stage.removeEventListener(MouseEvent.MOUSE_DOWN, onDown);
private function onSelected(evt:Event):void{
fileRef.addEventListener(Event.COMPLETE, onLoaded);
fileRef.load();
fileRef.removeEventListener(Event.SELECT, onSelected);
private function onLoaded(evt:Event):void{
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onComplete);
loader.loadBytes(evt.target.data);
addChild(loader);
fileRef.removeEventListener(Event.COMPLETE, onLoaded);
private function onComplete(e:Event):void
var loaderInfo:LoaderInfo = e.target as LoaderInfo;
loaderInfo.removeEventListener(Event.COMPLETE, onComplete);
var loader:Loader = loaderInfo.loader;
trace("loader size: ", loader.width, loader.height);
Thank you.
But I know that method works, that's the method to load the image. The problem is that after you load it, it has 0 (zero) width and height even though the image displays. So I can't manipulate it as I can't find it's width and height.
sorry i initially left a bit off and have since updated the code.
if you try and get the width and height of loader just after you call loadBytes you will get 0, 0
you have to setup and eventlistener for Event.COMPLETE and when you receive that you can access the width and height
I see.
I didn't though that loadBytes was actually a loading process which of courses needs an onComplete event. It though it just dumps the bytes into the loader object since the image is already loaded into RAM.
Tnx mate!
no worries
the file reference loads the bytes into a ByteArray. Loader then needs to load the bytes from the ByteArray. It will be pretty quick but you still have to wait
