lilhcoss
ayuda con illustrator cs3
Apr 10, 2012 11:32 PM
Tags: #illustrator #filters #formats
si ya se que ya nadie lo usa pero es el que tenemos en el trabajo y nadie me ha podido ayudar!!!!
coloco mis crop marks y cuando trato de salvar para web NO RESPETA LAS CORP MARKS Y ME EXPORTA TODO MI DOCUMENTO COMPLETO, NO COMO HASTA AYER LO HACIA!!!!
ESTOY DESESPERADA PUES NO ENCUENTRO NADA DE INFO AL RESPECTO!!!
por cierto, el archivo lo guardo como illustrator con las crop marks y lo abro en pdf SI LAS RESPETA, CREO QUE EL PROBLEMA ES CON SAVE FOR WEB!!!
     ayuuuuuuda por favor!!!!!!!
    Apr 11, 2012 8:54 AM   in reply to lilhcoss
    lilhcos,
    Usted puede usar este para traducir la respuesta:
    http://translate.google.com/#en|es|
    Have you:
    1) Created a rectangle where you want the Crop Area (or Crop Marks),
    2) With the rectangle selected Object>Crop Area (or Crop Marks)>Make?
    If you have, and if it worked yesterday, you may try the following (you may have tried/done some of them already) and see whether it helps:
    1) Close down Illy and open again;
    2) Restart the computer;
    3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup;
    4) Move the folder with Illy closed;
    5) Look through and try out the relevant among the Other options;
    Even more seriously, you may:
    6) Uninstall, run the Cleaner Tool, and reinstall.
    http://www.adobe.com/support/contact/cscleanertool.html
    Apr 11, 2012 9:03 AM   in reply to Jacob Bugge
    Hola lilhcos, si su problema no se soluciono con la ayuda en ingles, aqui le dejo la direccion del foro en español, tal vez ahi pueda encontrar mas ayuda
    http://forums.adobe.com/community/international_forums/espanol
    Hi Jacob, thanks for helping, I'm posting the link for the spanish forum, he/she might get help there.
    Apr 11, 2012 9:21 AM   in reply to CarlosCanto
    Let us hope it works either way, Carlos.
    At least one of the natives there, Claudio, has seen this thread already, as you can see from this:
    http://forums.adobe.com/thread/988243?tstart=0
    I wonder how intelligible an English>Spanish is in a case like this.
    Apr 11, 2012 10:04 AM   in reply to Jacob Bugge
    Jacob, here is your text, translated to Spanish and back to English by Google:
    Do you:
    1) Create a rectangle where you want the area to crop (or crop marks)
    2) With the rectangle selected object> Crop Area (or crop marks)> do?
    If you have, and if what worked yesterday may prove the following (you may havetried / done some already) and see if it helps:
    1) Close and reopen Illy;
    3) Close Illy and press Ctrl + Alt + Shift / Command + Option + Shift during startup;
    5) Check out and test the relevance between the other options;
    Worse, you can:
    6) Uninstall, run the cleanup tool and reinstall.
    And I have not offered any help because I have never used Illustrator in the last decade, and only a few times before that... If the original poster comes back and doesn't post/receive an answer in the forum in Spanish, I will translate your answer form him, should he need it.
    Apr 11, 2012 2:38 PM   in reply to Claudio González
    Claudio,
    Thank you very much for the offer.
    The translation is quite impressive, very far from the old cold war test.
    In 4 and 5, it is important to keep the links (Move the Folder and Other Options) because they form small tutorials.
    But judging from post #4, lilhcoss has realized/got the solution, seemingly from Carlos, although this thread gives no clue as to how.
    Apr 11, 2012 2:51 PM   in reply to Jacob Bugge
    nope, not from me, I just posted a link to the spanish forum.
    In post # 4 he/she explained that a save for web pref file was created for no reason, and after deleting it all worked ok. Didn't mention how he/she found out.
    Apr 11, 2012 2:59 PM   in reply to CarlosCanto
    Thank you for clearing it up, Carlos.
    I guess we shall never know what really happened.
    And as you can see from post #3, this thread has been haunted in other ways.
