I 've created a shape (Rectangle) , Applied a rounded corners, expand appearance, and a linear gradient.
After that i added a stroke in the appearance panel (2pt wide), filled it with white and when I wanted to align this stroke to inside
I can't. The options "Align Stroke to inside" "Align Stroke to Outside" are greyed out .
What's wrong ?
Thank you
Hi Kililio
If your shape is using brushes you cannot select align inside or outside (just to center). Also if you have a custom width profile you cannot select that align options too. But using width profiles (or the Width Tool) you could achieve the result you want..as Monika mentioned.
Best Regards
Gustavo.
