reelhero
vertical centering off the page
Apr 8, 2012 8:46 PM
http://toddheymandirector.com/REEL/index_2012c.html
i was able to vertically center the site but if you resize the browser smaller it disappears off the page
same on the index page
http://toddheymandirector.com/index_2012jsh22.html
also there is a strange black box that loads in the center of the above page before the content appears
thanks for the help!
    Apr 8, 2012 8:49 PM   in reply to reelhero
    Sorrry, when I see a absolute positioned div in a layout I know there are going to be problems. I have also found two <body> tags; fortunately only one ending <body> tag.
    Solution: get rid of all positioning attributes and start with floats and margins.
    Gramps
    Apr 9, 2012 9:44 AM   in reply to reelhero
    Apr 9, 2012 9:50 AM   in reply to Ben Pleysier
    This may also help http://forums.adobe.com/thread/492638
    Gramps
    Apr 10, 2012 5:26 PM   in reply to reelhero
    View source to see the code.  No APDivs required.
    http://alt-web.com/TEST/Resizable-BG.shtml
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    Apr 11, 2012 10:23 AM   in reply to reelhero
    You've got some code errors.  Not sure what's causing the box to appear on page load.  Fix these problems first.
    On lines 163 and 170 you have 2 #wrapper divisions with conflicting CSS styles. Remove one or combine them.
    On lines 425 and 429 you have 2 <body> tags.  Only one <body> tag is allowed per document.
    Not sure which jQuery transitions you're going for.
    I did this basic jQuery demo a while back (the function code is near the bottom of the page):
    http://alt-web.com/DEMOS/jQuery-slide-n-fadeIn-demo.shtml
    Hope this helps,
    Nancy O.
    http://alt-web.com/
    Apr 11, 2012 10:28 AM   in reply to reelhero
    reelhero wrote:
    oh and nancy -- theres a strange sqaure thats loading in the center of the index page (these are all tests for now)
    do you know what causes that? something to do with the jquery slideshow maybe?
    That could be the slideshow 'loading' gif - minus the gif?
    Some slideshows have a loading image spinning around on page load while the images are loading. Not sure where you got the slideshow from but check to see if you have all the parts.
    Apr 11, 2012 10:38 AM   in reply to osgood_
    Your most likely missing the progress.gif in the loader: (see below)
    #supersized-loader { position:absolute; top:50%; left:50%; z-index:10; width:60px; height:60px; margin:-30px 0 0 -30px; text-indent:-999em; background-color:#111; background:rgba(0,0,0,0.8) url(../img/progress.gif) no-repeat center center; -webkit-border-radius:5px; -moz-border-radius:5px; border-radius:5px;}
    OR its not where it says it is on your server (in that case check the image path)
    of course if you prefer it not to appear just either get rid of the #supersized-loader <div> in your page OR add display: none; to the #supersized-loader css selector above.
    Apr 12, 2012 12:20 AM   in reply to reelhero
    It's in this file: /css/supersized.css
