1- The Curves Menu is uncomfortable due to a lack of contrast between points and lines. I would add off-white boxes rather than keeping the dark grays caled themed boxes. (aka it's hard to read)
2- When trying to over write a file I just saved, I tend to get weird error messages.
3- Camera RAW is MUCH better!
4- Content awareness tool is much faster and a slightly improved. The new tool is working as expected... Overall you my biggest complaint, apart from edges, is the inability to properly calculate for noise/sharpness sometimes. Nonetheless it is better though and I do find myself using it more often.
5- The Crop tool's movement feels a little weird, but maybe I need to use it more.
6- Wacom Brush Size/Hardness shortcut numbers are much appreciated and a great small add.
That's it for now!
1- The regular curves window. I apologize for not explaining myself better: The lines and points can become hard to read if there is no infograph behind them. I would suggest leaving the main "curves line" white and making the grid lines a duller white since they're very similar in tone to the gray boxes/background. Kind of helps after a long day!
2- For the past three days I've been having problems using "Save As", but ever since yesterday CS6 has been running perfectly smooth. I'll update this post if it happens again though.
Thank you Chris!
It seems everyone is having trouble being explicit and accurate, here.
I thought that maybe everyone is talking about the Curves control that's displayed in the now selectable theme in the Properties panel, but I'm not having any problem discerning the lines and points from the background myself - they seem nice and bright against the dark background. Is this not what you're seeing?
Could there be another "Curves" function beyond what I've shown above that really is hard to see?
-Noel
Thanks for your feedback!
We are happy to hear you like some of the improvements. (Camera RAW and Wacom stuff).
The crop takes a while to get used to, but most people like it better once they use it for a while (they resist for a while and even use legacy settings, but eventually come around and like it).
We will take a look at the contrast with UI and consider user suggestions for future versions.
About error messages:
When you get error messages, it is hard to debug what is going on if you don't attach a screen capture or the text that you receive along with the sequence of events that got you there. If you get the message again, please capture it and give us an update.
Pattie
from jmarquez:
Here is how my basic layout looks. The diagonal to the left of center is barely readable. I can use it but it slows me down, especially if I am attempting to pick a specific point in the darkness. It's like trying to find the restroom in a campground at midnight with no moon. The portion illuminated by the histogram works well as does the Image>Adjust>Curves box does.
What mitigates it is that we now have a way to highlight a specific point in the image with the click and drag tool. That ultimately is the beast way to accurately find a particular value to tweak.
My suggestion to Adobe is to lighten up the grid, perhaps make it sensitive to the surrounding values. It wouldn't take much. Notice how big I made the Curves box relative to the rest of the layout. That helps also.
Pattie,
The crop takes a while to get used to, but most people like it better once they use it for a while.....
..is pretty lame, imo. I don't particularly like all the additional steps I MUST do just to use the tool as a normal crop. It's placing the burden on the user to figure out how to work around something we have used with little concern in the past. It's clunky, it takes over and finally doesn't even let go once the crop is finished. So now, one more step to truly exit. But wait! There is a workaround to get back to normal. Select the Perspective Crop Tool and just don't bother to correct perspective. You give up the convenience of having the ratios picked for you, but it appears to be business as usual.
I came across a situation with the crop tool today. I had used it non destructively and come out of Crop. I later wanted to adjust the position of the image within the frame, so hit the 'c' key, but was unable to move the image within the fram unless I first nudged a handle. Is there a workaround? I just tried it again, and I don't actually have to nudge a handle. Just click on one. That's no hardship. Is there a hot key though?
I'm really trying to understand things here, and nail the problem down, so please don't get frustrated. We are entering into a territory where each of us is basing our comments on what we see, specifically, on our OWN monitors, and we may not be seeing the same things!
Just as you have written it, I cannot find a "diagonal to the left of center" that is anything like "barely readable". The only diagonal that I see left of center is the RGB luminance line that runs diagonally across the Curves control in the Properties panel, which I have identified with red arrows in the image just below. And to me it's brilliant - anything but barely readable.
But just to make absolutely sure we're on the same page here... This is exactly what you're talking about, right?
To reiterate, what I have identified with the red arrows above is NOT AT ALL difficult to see from where I sit. It's absolutely brilliant against the dark background.
So either we're SEEING two different things, or we're TALKING ABOUT two different things.
If we're SEEING different things, our monitors must showing us quite different displays given the same pixel data, and there must be a response characteristic or calibration problem responsible for the difference.
Now, another big thing I *DO* notice, and keeping in mind you do a fair bit of black and white work, Lawrence, is a big difference between the histogram color itself in a grayscale image vs. that in an RGB image.
Could it be you're talking about the difficulty in seeing the white diagonal line where it crosses in front of active histogram columns (white on light gray)? I agree that there is too little difference there, and wonder why the histogram color isn't more like the RGB histogram color.
-Noel
It's the relationship between the plot and the grid, and in this case, the plot is a straight line diagonal. In any case, I cannot see the grid well anywhere that it shows gray on gray for the grid, not the plot.
There is no doubt that the presentation of the Curves using Image>Adjust is optimum. No squinting or guessing. Unfortunately it is also inelegant with respect to the CS6 UI, and elegance wins.
Let's put it this way. If the plot represented an aircraft final approach ramp, which presentation would you want so as to know at a glance, the conditions necessary to make an informed judgement? Not the elegant one imo!
I frequently set a curve using numbers such as Input 126, output 118 when burning down corners of an image. Much easier to move the cursor to 128/128 for starters using the Image>Adjust version.
BTW, I noticed a problem running through this process which is to me a minor bug. I'll present it next.
Message was edited by: Hudechrome
I'm thinking monitors, eyes, and personal preferences play a big part this. I simply can't agree that the dark on light presentation is in any way "optimum".
While I agree that the grid with the dark background is not much brighter than the background color, I personally don't feel that gets in the way of anything. Just as it is, I don't have a problem seeing it and I find the light info on dark background motif MUCH closer to "optimum".
For ultimate accuracy, use the input/output numbers and push the points around with the arrow keys. For touchy-feely results, look at the image while dragging with the mouse.
-Noel
Referring to the image I included in Post #8, notice the tonal value/color of the Histogram palette above the Navigator image.
Now notice the color here.
I can get to the same presentation as in Post 8 by doing the following:
1) Open a Gray Scale Image
2) Add the Curves 1 Layer
3) Convert it to RGB. Do not Flatten. Notice the gray-green shift in the Histogram.
4) On the History Palette go back one step to Curves 1 Layer. Note the Histogram is now white and it stays white from that point on.
If you start with an RGB, the greenish-gray Histogram shows up with color spikes visible. Converting to Gray Scale kills the green-gray and the color spikes presenting only white. Converting again from Grayscale to RGB shows the Histogram as all white, no colors at all. Then things got really complicated. I could no longer open an image from Bridge. Instead I found a really bizarre presentation of an earlier image tiled randomly. I quit Photoshop and Bridge, then attempted to re open Photoshop. It would not open. Checking Processes, I found several instances of Photoshop running. I killed them all then Photoshop opened fine.
Just in case, here's system info:
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Windows 7 64-bit
Version: 6.1 Service Pack 1
System architecture: AMD CPU Family:15, Model:5, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 4
Processor speed: 2800 MHz
Built-in memory: 12287 MB
Free memory: 9430 MB
Memory available to Photoshop: 11001 MB
Memory used by Photoshop: 73 %
Image tile size: 132K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Radeon HD 5670
Display: 2
Display Bounds:= top: 0, left: 1920, bottom: 1024, right: 3200
Display: 1
Display Bounds:= top: 0, left: 0, bottom: 1200, right: 1920
Video Card Number: 1
Video Card: ATI Radeon HD 5670
OpenCL Unavailable
Driver Version: 8.951.0.0
Driver Date: 20120308000000.000000-000
Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,ati umd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdv a,atiumd6a.cap,atitmm64.dll
Video Mode: 1920 x 1200 x 4294967296 colors
Video Card Caption: ATI Radeon HD 5670
Video Card Memory: 512 MB
Video Rect Texture Size: 16384
Serial number: Tryout Version
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\HUDECH~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
I:\, 170.1G, 126.4G free
G:\, 20.4G, 18.7G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2012/01/18-15:07:40 66.492997 66.492997
adbeape.dll Adobe APE 2012/01/25-10:04:55 66.1025012 66.1025012
AdobeLinguistic.dll Adobe Linguisitc Library 6.0.0
AdobeOwl.dll Adobe Owl 2012/02/09-16:00:02 4.0.93 66.496052
AdobePDFL.dll PDFL 2011/12/12-16:12:37 66.419471 66.419471
AdobePIP.dll Adobe Product Improvement Program 6.0.0.1642
AdobeXMP.dll Adobe XMP Core 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPFiles.dll Adobe XMP Files 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPScript.dll Adobe XMP Script 2012/02/06-14:56:27 66.145661 66.145661
adobe_caps.dll Adobe CAPS 5,0,10,0
AGM.dll AGM 2012/01/18-15:07:40 66.492997 66.492997
ahclient.dll AdobeHelp Dynamic Link Library 1,7,0,56
aif_core.dll AIF 3.0 62.490293
aif_ocl.dll AIF 3.0 62.490293
aif_ogl.dll AIF 3.0 62.490293
amtlib.dll AMTLib (64 Bit) 6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00) 1.000000
ARE.dll ARE 2012/01/18-15:07:40 66.492997 66.492997
AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
Bib.dll BIB 2012/01/18-15:07:40 66.492997 66.492997
BIBUtils.dll BIBUtils 2012/01/18-15:07:40 66.492997 66.492997
boost_date_time.dll DVA Product 6.0.0
boost_signals.dll DVA Product 6.0.0
boost_system.dll DVA Product 6.0.0
boost_threads.dll DVA Product 6.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.0.5.19287 2.0.5.19287
CoolType.dll CoolType 2012/01/18-15:07:40 66.492997 66.492997
data_flow.dll AIF 3.0 62.490293
dvaaudiodevice.dll DVA Product 6.0.0
dvacore.dll DVA Product 6.0.0
dvamarshal.dll DVA Product 6.0.0
dvamediatypes.dll DVA Product 6.0.0
dvaplayer.dll DVA Product 6.0.0
dvatransport.dll DVA Product 6.0.0
dvaunittesting.dll DVA Product 6.0.0
dynamiclink.dll DVA Product 6.0.0
ExtendScript.dll ExtendScript 2011/12/14-15:08:46 66.490082 66.490082
FileInfo.dll Adobe XMP FileInfo 2012/01/17-15:11:19 66.145433 66.145433
filter_graph.dll AIF 3.0 62.490293
hydra_filters.dll AIF 3.0 62.490293
icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
image_compiler.dll AIF 3.0 62.490293
image_flow.dll AIF 3.0 62.490293
image_runtime.dll AIF 3.0 62.490293
JP2KLib.dll JP2KLib 2011/12/12-16:12:37 66.236923 66.236923
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 10.0
LogSession.dll LogSession 2.1.2.1640
mediacoreif.dll DVA Product 6.0.0
MPS.dll MPS 2012/02/03-10:33:13 66.495174 66.495174
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CS6 CS6
Plugin.dll Adobe Photoshop CS6 CS6
PlugPlug.dll Adobe(R) CSXS PlugPlug Standard Dll (64 bit) 3.0.0.383
PSArt.dll Adobe Photoshop CS6 CS6
PSViews.dll Adobe Photoshop CS6 CS6
SCCore.dll ScCore 2011/12/14-15:08:46 66.490082 66.490082
ScriptUIFlex.dll ScriptUIFlex 2011/12/14-15:08:46 66.490082 66.490082
tbb.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 6.0.0.24
WRServices.dll WRServices Friday January 27 2012 13:22:12 Build 0.17112 0.17112
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Accented Edges 13.0
Adaptive Wide Angle 13.0
ADM 3.11x01
Angled Strokes 13.0
Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Bas Relief 13.0
BMP 13.0
Camera Raw 7.0
Chalk & Charcoal 13.0
Charcoal 13.0
Chrome 13.0
Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Color Halftone 13.0
Colored Pencil 13.0
CompuServe GIF 13.0
Conté Crayon 13.0
Craquelure 13.0
Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Crop and Straighten Photos Filter 13.0
Crosshatch 13.0
Crystallize 13.0
Cutout 13.0
Dark Strokes 13.0
De-Interlace 13.0
Dicom 13.0
Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Diffuse Glow 13.0
Displace 13.0
Dry Brush 13.0
Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Embed Watermark 4.0
Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Extrude 13.0
FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Fibers 13.0
Film Grain 13.0
Filter Gallery 13.0
Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Fresco 13.0
Glass 13.0
Glowing Edges 13.0
Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Grain 13.0
Graphic Pen 13.0
Halftone Pattern 13.0
HDRMergeUI 13.0
IFF Format 13.0
Ink Outlines 13.0
JPEG 2000 13.0
Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Lens Blur 13.0
Lens Correction 13.0
Lens Flare 13.0
Liquify 13.0
Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mezzotint 13.0
Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Mosaic Tiles 13.0
Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Neon Glow 13.0
Note Paper 13.0
NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Ocean Ripple 13.0
Oil Paint 13.0
OpenEXR 13.0
Paint Daubs 13.0
Palette Knife 13.0
Patchwork 13.0
Paths to Illustrator 13.0
PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Photocopy 13.0
Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Pinch 13.0
Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Plaster 13.0
Plastic Wrap 13.0
PNG 13.0
Pointillize 13.0
Polar Coordinates 13.0
Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Poster Edges 13.0
Radial Blur 13.0
Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Read Watermark 4.0
Reticulation 13.0
Ripple 13.0
Rough Pastels 13.0
Save for Web 13.0
ScriptingSupport 13.0
Shear 13.0
Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Smart Blur 13.0
Smudge Stick 13.0
Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Spatter 13.0
Spherize 13.0
Sponge 13.0
Sprayed Strokes 13.0
Stained Glass 13.0
Stamp 13.0
Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Sumi-e 13.0
Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Targa 13.0
Texturizer 13.0
Tiles 13.0
Torn Edges 13.0
Twirl 13.0
U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Underpainting 13.0
Vanishing Point 13.0
Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Water Paper 13.0
Watercolor 13.0
Wave 13.0
Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
Wind 13.0
Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
ZigZag 13.0
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Kuler
Installed TWAIN devices: NONE
I can confirm there's something funky going on in the Histogram display. It actually went black on me when I switched to grayscale in testing what you described. Then when I went back to RGB it just stayed very light gray, without showing the three color channels and how they fail to overlap.
Update: Note the value of the Channel: field in the Expanded View of the Histogram dialog. Note that it's "Colors" when you open an RGB document and see the greenish-gray display, and "RGB" when you see the light gray display. It really should go back to Colors.
-Noel
Checked the Expanded View and I get the same. When going back to RGB in History, you do have the choice of Colors in the drop down. It is consistent because if you pick RGB instead of Colors from the drop down, the White RGB comes up.
Also, try this. Open the drop down in Expanded View and turn off "Channels in Color". The black display now turns white and visa versa when reversing "Show Channels in Color".
There is a method to their madness. Madness, I say! It is pure madness! ![]()
Maybe I need to go back to my dark.... NAH! I get funny smells on my hands, especially after handling onions, then fixer! ![]()
I just wanted to chime in and say I find the grayscale image version of the Properties panel version of the Curves editor a bit hard to read, too. The white curve plot is just too similar in luminance to the histogram to easily differentiate the two in the areas where they cross. The brighter histogram also increases the contrast between the histogram and the gridlines, too much for my taste. At that level, I think the grid lines start to become a bit distracting.
I'd very much perfer if the panel used the same color scheme for grayscale images as it does for the luminance setting for RGB images (i.e. darker histogram). I'm testing this on a hardware-calibrated wide-gamut Eizo monitor, so I don't think the problem is a display issue.
To Trevor: clicking Return key (mac) or Enter key (win) will make the crop modal.
Or you can euse arrow keys to nudge the image under the crop box.
