cmbap
Whenever I try to get Premiere 5.5 to export to Prores an aspect ratio shift occurs for no reason.
Apr 11, 2012 8:07 AM
Tried everything to get this working: from setting up a Prores 422 preset, to messing with every possible setting in the export boxes. Bizarrely, After Effects has no such problem, ever.
What's up Adobe?
cb
    Apr 11, 2012 8:38 AM   in reply to cmbap
    FAQ: What information should I provide when asking a question on this forum?
    In addition, what are your sequence and desired export settings?
    Apr 11, 2012 8:39 AM   in reply to cmbap
    Try to select "Square Pixels"
    In Export settings> Basic Settings > Aspect : [Square Pixels]
    Cheers
    Apr 11, 2012 11:05 AM   in reply to cmbap
    "for no reason"
    Some how, I doubt this is a true statement.
    That is true.  Wrong results are usually operator error.  Agreed?
    What's up Adobe?
    So, this is Adobe's fault, I guess.
    Apr 11, 2012 11:33 AM   in reply to cmbap
    Well, gosh, you did such a bangup job of describing your problem, and the steps you took to create it, we're really going to miss you around here.
    Apr 11, 2012 11:43 AM   in reply to cmbap
    I export to ProRes on a daily basis, SD and HD, and I have not experienced an aspect ratio shift once, unless I instructed Pr to do so.
    If you want Adobe to "get on this," you need to describe a problem that's reproducable on other systems.  You have done nothing to this end, just made vague unsupported claims.
    Apr 11, 2012 12:48 PM   in reply to cmbap
    I want someone who actually works for Adobe to get on this.
    In order to ensure that, you need to pay for a support ticket.  'Round here it's mostly us users.  Employees do pop in from time to time, but it's not guaranteed.
