Epictom123 Calculating status...
Hi guys i'm making a mobile app with flash builder but i stumble upon an error. In short terms, you put a text in a text input, u click a button and it only lists the things from the database with that imputted text in it. Here are the codes:
First the Homeview.mxml:
<?xml version="1.0" encoding="utf-8"?>
<s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark" title="Home"
xmlns:dao="dao.*">
<fx:Declarations>
<dao:RoosterDAO id="srv"/>
</fx:Declarations>
<s:Label x="11" y="6" fontSize="36" text="Klas:"/>
<s:TextInput id="Klas" x="91" y="6" width="262" height="30"/>
<s:Button id="btn" x="361" y="0" height="40" label="Button" click="data=srv.findByKlas(Klas.text)"/>
<s:List id="list" top="48" bottom="0" left="0" right="0"
dataProvider="{data}">
<s:itemRenderer>
<fx:Component>
<s:IconItemRenderer
label="{data.Klas} - {data.Vak} - {data.Docent}"
messageField="Positie"/>
</fx:Component>
</s:itemRenderer>
</s:List>
</s:View>
and secondly the sql .as file :
package dao
import flash.data.SQLConnection;
import flash.data.SQLStatement;
import flash.filesystem.File;
import flash.filesystem.FileMode;
import flash.filesystem.FileStream;
import mx.collections.ArrayCollection;
public class RoosterDAO
public function getItem(id:int):Rooster
var sql:String = SELECT id, Klas, Vak, Docent, Lokaal, Positie, Type FROM Rooster WHERE id=?;
var stmt:SQLStatement = new SQLStatement();
stmt.sqlConnection = sqlConnection;
stmt.text = sql;
stmt.parameters[0] = id;
stmt.execute();
var result:Array = stmt.getResult().data;
if (result && result.length == 1)
return processRow(result[0]);
else
return null;
public function findByKlas(searchKlas:String):ArrayCollection
var sql:String = SELECT * FROM rooster WHERE Klas LIKE ?;
stmt.text = sql;
stmt.parameters[0] = % + searchKlas + %;
stmt.execute();
if (result)
var list:ArrayCollection = new ArrayCollection();
for (var i:int=0; i<result.length; i++)
list.addItem(processRow(result[i]));
return list;
else
return null;
protected function processRow(o:Object):Rooster
var rooster:Rooster = new Rooster();
rooster.id = o.id;
rooster.Klas = o.Klas == null ? : o.Klas;
rooster.Vak = o.Vak == null ? : o.Vak;
rooster.Docent = o.Docent == null ? : o.Docent;
rooster.Lokaal = o.Lokaal == null ? : o.Lokaal;
rooster.Positie = o.Positie == null ? : o.Positie;
rooster.loaded = true;
return rooster;
public static var _sqlConnection:SQLConnection;
public function get sqlConnection():SQLConnection
if (_sqlConnection) return _sqlConnection;
var file:File = File.documentsDirectory.resolvePath(rooster.db);
var fileExists:Boolean = file.exists;
_sqlConnection = new SQLConnection();
_sqlConnection.open(file);
if (!fileExists)
createDatabase();
populateDatabase();
protected function createDatabase():void
var sql:String =
CREATE TABLE IF NOT EXISTS rooster ( +
id INTEGER PRIMARY KEY AUTOINCREMENT, +
Klas VARCHAR(50), +
Vak VARCHAR(50), +
Docent VARCHAR(50), +
Lokaal VARCHAR(50), +
Positie VARCHAR(50), +
Type VARCHAR(50), ;
stmt.text = sql;
stmt.execute();
protected function populateDatabase():void
var file:File = File.applicationDirectory.resolvePath(assets/rooster.xml);
var stream:FileStream = new FileStream();
stream.open(file, FileMode.READ);
var xml:XML = XML(stream.readUTFBytes(stream.bytesAvailable));
stream.close();
var RoosterDAO:RoosterDAO = new RoosterDAO();
for each (var emp:XML in xml.Rooster)
rooster.id = emp.id;
rooster.Klas = emp.Klas;
rooster.Vak = emp.Vak;
rooster.Docent = emp.Docent;
rooster.Lokaal = emp.Lokaal;
rooster.Positie = emp.Positie;
rooster.Type = emp.Type;
The error is at the findByKlas function and it goes like this:
SQLError: 'Error #3115: SQL Error.', details:'no such table: 'rooster'', operation:'execute', detailID:'2013'
at flash.data::SQLStatement/internalExecute()
at flash.data::SQLStatement/execute()
at dao::RoosterDAO/findByKlas()[C:\Users\Thomas\Adobe Flash Builder 4.6\ARHC test\src\dao\RoosterDAO.as:36]
at views::MainHomeView/__btn_click()[C:\Users\Thomas\Adobe Flash Builder 4.6\ARHC test\src\views\MainHomeView.mxml:11]
If you need any more information just ask me (:
1 Reply
Latest reply:
_spoboyle, Apr 12, 2012 1:12 AM
